idle speed stuck
Discussion in 'XJ Technical Chat' started by joejr2, May 15, 2020.
  1. joejr2
    Santa Fe,NM
    after rebuilding the carbs,wet testing the fuel levels and synching them with vacuum gauges the bike runs well.
    but I can't lower the idle speed below 2k. no hanging idle on acceleration and it starts right up. the only other thing I can think of is the mixture screws. I set them at 2.5 turns out. Since I am unable to lower the idle below
    2k would that indicate too rich or too lean ? Also no air leaks that I could find with a can of starter fluid.
  2. Polock
    2.75 to 3 might be better, does it have a "off idle bog" that would be lean.
    2K, i'd look at that sync again. if your using 4 separate gauges, gang them all together and see if they all read the same
  3. joejr2
    Santa Fe,NM
    Used 2 gauges. no bog fires up on throttle. drops back to 1.5 then up to 2 and stays there. 2 gauges 4 to 3, 1 to 2, 2 to 3
  4. Rusty81
    Rusty81 Member
    Sarnia On, Canada
    Is the throttle cable not resetting? Holding the butterflies open?
