Ignition help keys will not turn?
Discussion in 'XJ Technical Chat' started by timothy guay, Aug 1, 2018.
  1. timothy guay
    timothy guay New Member
    Missouri
  2. timothy guay
    Missouri
    Unless I remove the locking device, keys will not turn, correct keys. Will this self correct when mounted? I’m not quite sure if this is normal for a new switch or how to fix? Key position is currently in p position with locking pin not extended out.
  3. hogfiddles
    Try pushing the key In farther and turn. You may be caught between park and lock
  4. timothy guay
    Missouri
    Tried that. I actually just took off the base, manually pushed the pin down and held it down while inserting the round catch. Reassembled and now the key turns correctly. Thanks for the reply hogfiddles!
  5. hogfiddles
    Work some powdered graphite down in there to lube things up
    timothy guay likes this.
