ignition relocation
Discussion in 'XJ Modifications' started by Scottie1, Feb 19, 2018.
  1. Scottie1
    Scottie1 Active Member
    Columbia SC
    I am relocation my ignition switch and don't want to use the stock one I want something a bit smaller. I know I need a 3 wire switch but do I also need a 2 position switch. Also and recommendations to which ignition switch would work.
    the oem switch has off on park and lock.
    you just need a keyed on off switch, the oem switch has input from main fuse and output to the other fuses, when in on position
    you need one amp rated for main fuse at 14 volts
    you could use a starter switch and not use the starter button
  3. LarryMc
    LarryMc Active Member
    Lakewood, WA
    Most aftermarket switches will not include the lock function.
  4. Scottie1
    Columbia SC
    I ended up re using the stock one took the lock mechanism out and cut it down. Made a bracket and connected it to the battery ground lead on the engine.
  5. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    what do you mean "connected it to the ground lead on engine" .
    theres no ground connection on the ignition switch.
    stu
  6. XJ550H
    mounted it on the ground wire with a bracket
    Scottie1 likes this.
  7. Scottie1
    Columbia SC
    Sorry being an ex pat living in USA I still use English terms I am learning slowly and surely
