In desperate need of help to fix my xj
Discussion in 'XJ Technical Chat' started by Ryan25, Sep 1, 2016.
  1. Ryan25
    Ryan25 New Member
    South Africa
    Hi please can I ask for some help. I'm busy restoring my xj650 and my 750 and I'm am desperately trying to find main bearings and big end bearings. All the yamaha dealers can't help as they say they have discontinued these parts. Is there anyone that can help with advice on where I can get from as I'm trying to avoid just scrapping these two projects as they are nice bikes. Regards Ryan
  2. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    Have you contacted Len? You can us the link at the top of the page, right hand side (states "click here for catalog" or XJforever), and connect with him, or start a conversation with him. He can get most parts, even ones that are not available from dealers.
  3. TheCrazyGnat
    Central PA
    ^^+1 check with Len to see if he has them in stock. Have you done the math to figure out which color sizes you need?
    Used or NOS. You'll have to hunt and search and get to know old people who have stashes. Sometimes they come up on Ebay.
    Mow for the big question: What happened to the engine? Bearing replacement is not commonly needed. Very few XJ engines have enough hours on them to have the bearings out of spec.
    CruzNCycles and Xjrider92117 like this.
  5. Ryan25
    Ryan25 New Member
    South Africa
    Hi thanks you for your replies. The primary chains guides both broke causing the chain to rub on the oil tube. The metal fillings have scored the bearings. I don't want to chance it and cause more damage. How do I get hold of len to see if he has stock is there a email adress o I make contact with him. I'm very surprised that the agents have discontinued these parts as the bikes are very nice machines regards ryan
  6. Ryan25
    Ryan25 New Member
    South Africa
    The colours worked out to one being a green set for mains and blue for big ends for the 650 and the 750 mains work out to black and big ends Brown regards ryan
  7. TheCrazyGnat
    Central PA
    If you click on the link at the top right of the page you will be taken to xj4ever's catalog. You can start a conversation with him by clicking on one of the xj4ever icons next to the section titles and selecting start a conversation.
  8. TheCrazyGnat
    Central PA
    For your consideration, here are the part numbers that I found while I was researching to replace them myself (an 82 XJ750 Maxim, I believe that these are used across the XJ series but you would have to verify that):
    Rods
    4 Green 5G2-11656-30-00
    3 Brown 5G2-11656-20-00
    2 Black 5G2-11656-10-00
    1 Blue 5G2-11656-00-00
    Main (oil holes 3 CRSF 1 U.R.)
    5 Yellow 4H7-11416-41-00
    4 Green 4H7-11416-31-00
    3 Brown 4H7-11416-21-00
    2 Black 4H7-11416-11-00
    1 Blue 4H7-11416-01-00
    Main (no oil holes 4 CRSF 3 U.R.)
    5 Yellow 5G2-11418-40-00
    4 Green 5G2-11418-30-00
    3 Brown 5G2-11418-20-00
    2 Black 5G2-11418-10-00
    1 Blue 5G2-11418-00-00
    The mains with no oil holes were superseded at some point in between the release of these bikes and when the bearings were NLA. They were simply replaced with the ones with oil holes, so you can use those for both. It looks like these bearings were used in some of Yamaha's marine applications as well, so you might find them on some sites that cater toward that.
  9. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
  10. Ryan25
    Ryan25 New Member
    South Africa
    Still battling to make contact with one of the guys that might have the bearings. Can any one help with a email adress of some one as it's difficult to sort out parts when I am in SA
  11. Biker48
    Biker48 New Member
    If you have the originals you can obtain any bearing you need. I had to obtain some odd sized ones many years ago when I fitted a racing big end into a standard crankcase. There are bearing suppliers and makers. I suggest a google search should result in a list of suppliers. Many will ship internationally. PM me if you need help with addresses.
  12. k-moe
    We (collectively) have been down that road. Cost is the thing. A set of crank bearings can cost more than a used engine that's still in running condition.
