Inline fuel filter or individual carb fuel filter?
Discussion in 'XJ Technical Chat' started by maxsauve, Dec 28, 2019.
  1. maxsauve
    maxsauve New Member
    Montreal Canada
    Hey guys!
    I have a 1983 XJ750 Maxim and I just cleaned up my carbs and while removing the tank I noticed I didn't have an inline fuel filter on the fuel line going to the carbs. However, taking the carbs appart, I noticed that I had mesh filter on every float valve.
    My question is: Would it be a better idea to add a fuel filter (paper) on the line itself and keep the mesh filters, or remove the mesh filters and add the inline filter. Or just keep it as is.
    The tank barely as any rust inside and its running a gravity petcock.
  2. Cattleman XJ
    Cattleman XJ Member
    Texas
    I’d maintain at least 2 filters, and you already have one in your tank.
    I’m a fan of inline filters but I use the ones Chacal sells. They are brass elements I think.
    the float valve seat screens are a nice thought but I don’t think you can get them anymore. Myself and several others I’m sure don’t run them
  3. XJ550H
    The screen on the petcock standpipe is in no way a filter. It'll keep big stuff out, but anything smaller than 1mm will head straight into the carbs.
    Chacal still has a supply of the float seat screens, but they aren't realy needed unless a body wants to have a completly stock restoration for show (some clubs mark off points for any aftermarket part that's visible).
  5. maxsauve
    maxsauve New Member
    Montreal Canada
    Thanks guys! I had a set of spare carbs and the float set screens where brand new, so I'll used them instead!
  6. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I would still use and in-line filter. Better than the screens and a lot easier to replace.
    XJ550H likes this.
  7. Hillsy
    Hillsy Member
    The best filters are paper element, however some of them will not flow enough fuel in a gravity system (they are meant for fuel pumps).
  8. Timbox
    Stay away from the clear plastic filters if you are in a ethanol area. They will have a chemical reaction that will dis form and dis color the clear plastic.
  9. Polock
    way back in the day a guy could get add-on fuel filters with a magnet in them. might be a science project next summer
  10. XJ550H
    when I was young there were those who insisted on cow magnets strapped to the fuel line at the carbs in there cars and trucks
  11. XJ550H
    never had an issue with the clear filters but I change them every year
  12. Timbox
  13. XJ550H
  14. Jetfixer
    I use a Briggs & Straton lawn mower plastic filter . And of course the petcock filter inside the tank . I change the filter every once in awhile these red filter have a mesh screen inside.
  15. XJ550H
    the better the filter on the out side the less crap gets through to the carbs
  16. tabaka45
    Brunswick, Georgia
  17. Ryengoth
    Ryengoth Active Member
    Wilmington, NC
    Did they also buy the Turbinator for their throttle body?
  18. Tim O
    Tim O Active Member
    Charlottesville, VA
