Intake Boot Repair - Bicycle Inner Tube Bandages
Discussion in 'XJ DIY How-To Instructions' started by hogfiddles, Jan 13, 2025.
  1. hogfiddles
    Here’s an inexpensive repair for your cracked intake manifold boots.
    1. Get a bicycle inner tube
    2. Cut 4 sections just the width of the intake boot
    3. Use a paper hole punch to create a hole for the vacuum port-- obviously measuring how far in from the edge you need to be....
    4. Slather the whole boot exterior with the rtv
    5. Slide the inner tube onto the boot to create a
    "Bandage"
    6. Do the other 3
    Now, re-install the carbs and see if there's any difference.
    DFox
    ZedTeam, atkiree, 4nik8r and 3 others like this.
  2. atkiree
    atkiree New Member
    Philadelphia, PA
    Exactly what I was looking for, thanks!
    hogfiddles likes this.
  3. OhioXJ750
    OhioXJ750 New Member
    Ohio, USA
    Nice work, always good to find a way around buying the "factory" stuff - which is very expensive even it you can find it!
