intake manifold
Discussion in 'XJ Technical Chat' started by Jamie Chetora, Mar 28, 2016.
  1. Jamie Chetora
    Jamie Chetora Member
    Fort Lauderdale FL USA
    im in serch of some decent used intake that bolt to the head mine are dry roted and cracking as ell as starting to rip in places causing intake leakes and shitty ideling / acceleration and i know the xjforever guys going to read this and yes put me down for 4 gaskets :p
    you can contact xj4ever directly by going to his web site www.xj4ever.com and his email is listed there or you can click on his logo in the upper right select the catagory of part you want then click on his avatar and start a conversation with him or look at the bottom of the first post where you will find his email
    so do you want these for a kawasaki or honda ?;)
    what bike do you needd them for?
    you can put your bike in your signiture line from your profile.
    or just list it with each post
  3. XJ550H
    1. you can fix them by cleaning them with carb cleaner then coating them with rtv gasket sealer and or cover them with heat shrink. there is also the inner tube method which involves rtv and inner tubes.
    there is a thread for the heat shrink I would use the glue lined shrink and a thread for the inner tube repair
    Video of my Carb Boot Repair
    carb boot repair-- heat shrink
    Repairing intake manifolds with bike tubes
  4. Jamie Chetora
    Seems like a quick fix but not a perminet solution to my but still something i can do till i get better intake boots
  5. k-moe
    If done correctly it is a permanant fix. I ran with repaired intake boots for three years and several members have had them that way for much longer. It wasn't that long ago that new intake boots were not available from any source.
