Is a clutch rebuild necessary?
Discussion in 'XJ Technical Chat' started by Jake750, Dec 7, 2020.
  1. Jake750
    Jake750 Member
    Detroit
    Yamaha yx600 radian. I just rebuilt my clutch. I should have read the manual a little more closely instead of skimming. The manual states that the points on the clutch plates should be staggered by 72 degrees, with the last two plates going in the 1 and 3 position.
    My brain decided to stagger them by 60 degrees with the last plate overlapping in the 1 position.
    I feel like it shouldnt be a problem but I figured I'd get a second opinion. Is it absolutely necessary for me to go back into the clutch or should it be okay probably?
    Thanks guys.
    specs are specs do it over.
    the positions are used to sling oil you do not want a dry clutch
    k-moe and Jake750 like this.
  3. Jake750
    Jake750 Member
    Detroit
    Balls...
  4. XJ550H
  5. Jake750
    Jake750 Member
    Detroit
    Yea I just checked out that thread. Going back into the clutch dosnt sound as bad as possibly dying on the highway I suppose.
    Also, was I supposed to put thread lock on the clutch bolts??
  6. Toomanybikes
    Tsawwassen bc
    Thread lock not needed, just correct torque. And did you pre soak the fibre plates?
  7. Yammaat
    Yammaat Active Member
    Netherlands
    I've never dealt with clutchissues on the yamaha's but why is it so comprehensive to do?
    My experience with clutches is; take m apart en just put the fresh plates in.
  8. Jake750
    Jake750 Member
    Detroit
    Yea I soaked all of the plates prior to installation.
  9. Polock
    never did that, never understood why i should. enlighten me
  10. k-moe
    To make sure that the friction plates are all evenly oiled from the get-go. It's really a holdover from when friction plates were lined with cork, but it's not a bad idea with modern friction materials either. It will ensure an even and smooth grab on the first ride after replacing the plates.
  11. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    You soak the friction plates in oil so you get your hands oily when you assemble the clutch.
    chacal likes this.
  12. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Its part of the right of passage pain that seems to be common here - if you haven't taken the medicine you can't be a real xj owner...
    Toomanybikes likes this.
  13. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    I rebuilt my clutch, like years ago, and to this day the bastard grabs, only on one of my bikes.
    So before I put it in gear, on the centre stand I spin it up to 3rd gear and back down again to first violently and then pop it into neutral before i hop off the centre stand.
    Just so I don't stall when I put it in first from neutral from the get go.
    Would love to know what the hell is going on, I am hoping it will go away one day but any opinion on that would be good.
    For the rest of the day there isn't an issue, of course.
  14. Franz
    Have you tried starting the engine and pulling the clutch lever a few times before putting it in gear to get more oil between the plates? I know it's unlikely that but it's easy to check it.
  15. cds1984
    Definitely tried that one.
    I think I may have a mismatch of a 900 basket to a 750 hub with 900 springs.
    I did replace all the fibre plates. the steel plates with genuine new plates and the springs, should've left it alone. ack!
    Although it never slips, as it did originally on acceleration.
    Even still it bugs me, feels like I'm going to screw up a drive dog somewhere in the gearbox when I pop it into first.
    Maybe the springs are too long.
    Hmm...
  16. Franz
  17. cds1984
    Thanks Franz.
    Time to just pull that sucker out again.
  18. Franz
    It is only happening with a cold engine. I would start the bike and let it get hot before trying to put it in gear to check if the problem disappears.
  19. chacal
    Did you use the 750 metal plates or the 900 plates? The 900 plates are about 0.5mm thicker (each one) than the 750 plates (friction discs are the same thickness between 750 and 900 engines), thus resulting in a taller stack, which will never fully release.
    Although, looking at the components list, it's probably best not to mix-and-match clutch components. Hub, baskets, springs, pressure plates all differ (but besides some obvious differences, I don't know what the specific are). XJ750RL and XJ900 RK/RL models use all the same components; once you get into the later model XJ900 engines, they are fully different (6 springs instead of 5), and of course all of the XJ750 (besides the 1984 RL version) differ from all of the 900 major parts.
    Franz likes this.
  20. cds1984
    On the day...
    I followed the 900 specs, since it is a 900 engine.
    When I actually did the fit I noticed that the codes on the hub were 750.
    Didn't think much of it at the time but now it seems to be the issue.
    Strip down and will report my findings. Damn got me again. Probably why it was slipping originally.
