It’s locked!
Discussion in 'XJ Technical Chat' started by Tim Dempsey, Sep 30, 2022.
Scrap it or get it running..?
  1. Part out
    0 vote(s)
    0.0%
  2. Get another engine
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Tim Dempsey
    Tim Dempsey New Member
    Jamestown Ohio USA
    I bought a non running ‘86 xj700 Maxim X and kinda wish I didn’t… when I first checked it out it did crank over slow, figured it was the battery, I hem haw’d and finally bought it because I’ve rescued a few before, but, by the time I got it and got it home I found it would not crank over and also found the spark plugs were not screwed in.. I think rain water got down in the cylinders and rusted more since I first checked it out, oh boy…
    Today I did the final try to get it turning, after I’ve poured oil and penetrating oil into the cylinders for about three weeks.. nothing, it’s not budging..
  2. Tim Dempsey
    Jamestown Ohio USA
    Oh by the way, it’s a water cooled model so, there aren’t many parts for it…….. ………
  3. k-moe
    Keep soaking it. Use a 50/50 mix of Acetone (or Diesel) and Automatic Transmission Fluid (heat it before pouring it into the cylinders, and don't skimp on how much you use each time. 1/4 cup per will do wonders). Give it a few more weeks of trying. If it still doesn't free-up then start selling parts of of it.
    Also keep in mind that stuck rings aren't the only thing that could be keeping her from spinning.
    Timbox likes this.
  4. Jetfixer
    Try to save it !! I would try a 50/50 mix of ATF and Acetone let it sit . I would try to rock it at the crank , remove left engine cover put a 19mm wrench on crank bolt . KMOE beat me to it lol
    Andrew Nichols and Timbox like this.
  5. Tim Dempsey
    Jamestown Ohio USA
    I have found another engine for it three hours away from me… I’ll have to make sure that one moves before maybe buy it…
  6. hogfiddles
    I’m in central NY.... if you wanna get rid of it!!
    Dave Fox
    The East Coast Parts Hoarder
    and
    Home for Orphaned, Unwanted, and Abused XJ’s
  7. Tim Dempsey
    Jamestown Ohio USA
    What would you give for it?
  8. hogfiddles
    Private message sent..... check your inbox
    dave fox
  9. Dan Gardner
    Minneapolis, MN
    Ha!
    HOAX - Home for Orphaned and Abused XJs.
    I think it works
  10. hogfiddles
    Unmmm, no— that’s why “Unwanted” is in there......
  11. Timbox
    Depending how the rest of the bike looks it might be worth saving. I mean you will have to pull the heads, cams and then the jugs over the winter. Have them honed a bit and make sure all is nice and clean. You should get new rings and make sure you measure them in the jugs so they fit right.
    All depends on how much energy you have and the tools and working area. It is a great way to learn the bike. 5 valve head on them and they are quick.
  12. hogfiddles
    Looks like it’s gonna head to the central NY XJ Herd
  13. Andrew Nichols
    Andrew Nichols Active Member
    Minneapolis, MN
    I was thinking of using;
    -Save The Secas (STS)
    -The Seca Whisperer
    -The Seca Necromancer
    -Secas 'R Us
    Now I just need to sell a couple of the 900 Seas and find a 650 Seca to resurrect.... Polish_20220722_214218495.jpg
    Still nowhere near the # that Dave has..,..
    Franz and Jetfixer like this.
  14. Tim Dempsey
    Jamestown Ohio USA
    Yep, it’ll be heading to Ny to hang out with a few other Maxims.
  15. hogfiddles
    It’ll be happy, and in good company :)
    Jetfixer likes this.
  16. Dan Gardner
    Minneapolis, MN
    I don't think that is a race that anyone will be winning any time soon.
