It’s over..
Discussion in 'XJ Technical Chat' started by Shavkat Yaparov, Apr 30, 2020.
  1. Shavkat Yaparov
    Shavkat Yaparov New Member
    Milwaukee, WI
    Gentlemen,
    I am a beginner rider, was working on my xj700 Maxim x for couple month. Today, took it for a little spin and the engine exploded.
    Parting it out
    So that’s that...
  2. Jonathon Kent
    Jonathon Kent Member
    Rochester NY
    How do you know the engine exploded? Did you disassemble ? Perhaps you could find donor engine. Plenty of wisdom and experience on this forum.
    Beck likes this.
  3. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    It's been known to happen. So sorry.
  4. Jonathon Kent
    Rochester NY
    What has been known to happen?
    Beck likes this.
  5. Franz
    Probably will be something simple that caused it to break down.
  6. Jonathon Kent
    Rochester NY
    That is part of the reason that I ask. I got my bike and the po hadn’t had it running for over 10 years and they ultimately thought it had major engine problems; just just not breathing right; btw had 15,000 ish miles when I got it. Take a couple of guesses on why it may not have been running right.
  7. StahlMaster
    Southgate, Michigan
    After being around XJ's for over 35 years I've met dozens of riders and more then a couple have been riding there bike when BAM, BOOM something let's loose.
  8. Shavkat Yaparov
    Milwaukee, WI
    I was riding at maybe 30 mph with my girlfriend in the back, all of a sudden pieces fly out from the right side of the bike and shoot in all directions. Leg covered in oil, shrapnel tore jeans slightly.. Swapping the engine is too expensive in my situation, and i think it would be wiser to part it out now... Very depressed. Loved that bike and put a lot of hours and money into it..
  9. a100man
    a100man Well-Known Member
    Bedford, UK
    Pics needed. Sounds like the clutch let go. Might not bee too bad to fix.
    Franz likes this.
  10. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Not enough obviously -(I meant love not money)
    Take a step back, have a long hard look at the clutch casing. It's obviously made a bid for freedom.
    As long as the main cases haven't been broken you may be in a cheap rebuild situation - clutch, casing, used prices...
    A pic might help someone help you - had you been working on that side of the engine?
    hogfiddles and Franz like this.
  11. SQLGuy
    SQLGuy Well-Known Member
    Wow. Sorry to hear this. Glad you guys are OK.
