Jaso ma vs jaso ma2?
Discussion in 'XJ Technical Chat' started by Kweb1889, Oct 16, 2020.
  1. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Hi I have an 81 xj550 maxim and an 82 xj650 maxim was wondering the difference between jaso ma and jaso ma2 can I use either or?
    Look here: Choosing Oil for a Wet Clutch Motorcycle
    To directly answer your question: MA2 has a higher friction index (preferable), but MA1 should be sufficient. IIRC the splitting of the MA spec into two parts was meant to provide a lower friction oil for the newer classic bikes (90's and up).
  3. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Ok last question here I bought 3 quarts of 10w40 oil meets jaso ma2 specs. And a new filter is this sufficient for an oil change? I've looked everywhere for how much oil I would need to do this and I cant find a straight answer. 1981 yamaha xj550j maxim
    3 quarts will be sufficient, but grab an extra quart to top the sump off. Ideally you want just a hint of a bubble at the top of the sightglass so you can monitor the oil level easily. If the bubble diasppears you've got leaky carbs. If it drops between rides, oil is being used or lost.
  5. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Ok and this bike has a wet sump correct or no? Sorry my xj650 and xj550 are my first XJS and I just got them both.
  6. k-moe
    Yes. Wet sump. No seperate oil tank.
  7. XJ550H
    550 oil amounts
    if your motor was completly drained 3.1 qt
    oil filter change 2.6 qts
    oil change only 2.3 qts.
    for the 550 put oil in untill you just see the air bubble at the top of the sight.
    when you are near the point of full add 1 to 2 oz at a time it takes a few mininutes to get where it goes
    RyanXJ550 likes this.
  8. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Ok so I bought 10w40 is that not a good idea I see your chart here says 20w40 or 10w30? Also its completely drained I had to replace the shift shaft seal. I also have a question if you dont mind giving a little advice on what to do next. I found a hole in what I think is the clutch cover I'll attach a pic and wanted to know what I should do about it. Replace it? Patch it with something? Does this hold fluid?
  9. jayrodoh
    jayrodoh YimYam
    Cleveland
    That’s the ignition pickup cover, no fluid under there but you will want to replace it as you don’t want the elements getting in there.
  10. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Thank you very much for the advice I ordered one off Ebay should be here in about 6 days.
  11. k-moe
    Meh. degrease and fill the hole with epoxy.
    But then..I don't care much about looks.
    Kweb1889 likes this.
  12. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Im sure you have at least one pristine bike k-moe !
  13. Kweb1889
    Kweb1889 Member
    Traverse city mi
    I was going to do that but I found a left side cover for $22 on Ebay so couldnt beat it lol. I am new to this I want to buy a scre on oil filter conversion kit for my 81 xj550j maxim from the supporting vendor but I'm not sure how? Help please.
  14. Kweb1889
    Kweb1889 Member
    Traverse city mi
    And is the 10w40 ok to use in this bike I've seen a lot of people using 20w40?
  15. k-moe
    for purcahces start a conversation with @chacal or email info@xj4ever.com
    At what outside temperatures will you be riding?
    That is what tells you which weight of oil to use.
  16. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Oh ok j wont be riding till spring as I live in Michigan. So probably 60+ @k-moe
  17. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    JB weld and build it up to fill the hole.
  18. k-moe
    Already resolved. He bought a replacement ignition pickup cover (the clutch cover was not the part that was damaged).
  19. Kweb1889
    Kweb1889 Member
    Traverse city mi
    Thank you for the advice even though it is resolved I appreciate all of you
