Just bought a 1980 xj650. Need help. Loads of issues.
Discussion in 'XJ Technical Chat' started by Xj650 New, Jul 23, 2020.
  1. Xj650 New
    Xj650 New New Member
    Kansas
    So I bought an xj650 maxim. Ran great for two days. Now it seems to be running cold on one side of engine (exaust wise) and very rich running conditions.( I determined by state of plugs). What should I do? Cannot seem to find parts for this bike. Something also to note this is my first motorcycle so I do not know alot of what to do.
  2. JCH
    JCH Active Member
    seattle wash
    You can find just about everything you need at XJ BIKES4 EVER.COM
    If you are not good with nuts and bolts ? like getting your hands dirty, have a lot of spare time it may be less aggravating and financially cheaper to buy a new retro bike
  3. Rusty81
    Rusty81 Member
    Sarnia On, Canada
    It runs (somewhat) so you know you have some air, fuel and spark. Electrics are working for you (Right?) so another plus. I’d confirm all cylinders are firing and check/clean your carbs and jets for fuel supply. If you can turn a wrench and read a manual, you’ll be okay for the most part. Tons of help on here, just search for topics or post your issues. As long as you're willing to listen, there’s folks on here happy to help.
    Good luck!
  4. Timbox
    Timbox Well-Known Member
    Have you looked inside the gas tank with a light? If she ran good for a few days and then started to give you issues, I am guessing carbs got junk in them. If there is no inline fuel filter in the fuel lines and with the age of these bikes, I would guess some junk got in the carbs. I could be wrong.
  5. Xj650 New
    Kansas
    Ok so electrics are good. Carb is well....very clean as this morning I cleaned it. It runs a little better. However half the engine no matter how warm I get it , the exaust is still cold. I'm not afraid to get dirty turn a wrench or anything like that. However after carbs electrics and fuel tank checks I'm drawing a blank on what else it could be. Perhaps valves? Or timing?
  6. Eric Hughes
    Eric Hughes Member
    North Carolina
    Trade the spark plugs between a warm and cold cylinder to see if the issue follows or stays?
  7. Xj650 New
    Kansas
    Upon inspection after cleaning and putting carburetors back I found an air leak issue. Theres a nipple for sync. That was loose when I removed it the idle picked up and engine ran fine until the throttle was revved and then it back fired. Any ideas of what could be going on?
  8. Timbox
    Good trouble shooting keep it up. Have you checked to make sure all the plugs are firing? Pull all the plugs put them back into their boots and crank the engine. See if you have spark on all 4. If you don't have spark, you will need to remove or clean some of the spark plug wire. Unscrew the boots from the wires and check the ends of the wires. If you see green nasty wire in the end, that will need to be taken care of.
