just got a maxim 550
Discussion in 'XJ Technical Chat' started by hughie1987, Mar 8, 2018.
  1. XJ550H
    seals go into hole in carbs where throttle shaft passes through carb body. butter flys are attached to throttle shafts look on #1 carb you will see a clip on the shaft the seal is under the clip and washer
    seal.JPG seal at end of shaft 1 on each side of carb
  3. hughie1987
    hughie1987 Member
    pennsylvania
    Ok cool thanks I'll check it out
  4. Andyam5
    Andyam5 Member
    Luton, UK
    Mlne did :(
