Just how hard would this be? Is it do-able? Electrical
Discussion in 'XJ Modifications' started by ryancdossey, May 14, 2012.
  1. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Any chance I could get a pic of it? We literally have the same model and year :)
  2. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    Sure you'll have to give me till the morning tho, I am at work till late...
  3. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    I think that I can wait till morning :) thanks man I appreciate it! so essentially you didn't have to really change a ton with it just kind of switch whats already there over and upgrade the speed sensor. good instructions came with it i presume?
  4. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    Yeah it was really easy, the hardest part was figuring out how an where to mount the speed sensor but i ended up zip tying it to the fork, and have the magnet on the rotor... I wired the gauges power thru the main aux hookup, the blue wire in the junction in the headlight bucket.
    here is the sensor on my fork
    here is where i tagged in the wire to the aux connection
    as you can see i relocated my ignition switch...
    there she lies...
    i didnt know what exactly to take pictures of, if there is anything in particular you need to see lemme know...
  5. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Thanks a ton man that looks really good! Could I get a shot of it on? Where did you move your ignition to? And wouldn't putting it on the rotor mess it up? Maybe I misunderstood..
  6. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    As far as the signals go...very doable. I used the LEDs on the VooDoo build..here
  7. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    I can solder will that be enough to make this work? lol
  8. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    Its on the rotor by the bolts... The magnet that is... You can see it in the pic actually. Sure ill take one of it on tonight. Ignition is mounted on right side cover. I will post a pic of that as well. :) hope i help lemme know if you need anything, and pm me if needed.
  9. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Excellent man will do! I really appreciate all of your help! And I can almost guarantee that I will.
  10. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    alright here is where the magnet is located. stuck it there five hundred miles ago, hasnt budged an inch.... i had it there previously because i had a sigma speed bike computer before the vapor.
    this feature is why i got rid of the aforementioned sigma speed
    and here is the side cover with starter button and ignition... sorry for the dark pic, late and crappy lights in the garage...
  11. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Looks really sweet man! I ordered my kit today!
    Will let you know how it comes and post pictures when I am done!
  12. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    Excellent! Any plans yet on mounting? You may nee to move/get a new ignition cylinder...
  13. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    I ordered one of their front fork bracket kits... Yet I didn't even think about that.... damn! Back to the drawing board. I'll probably try and mount it up front down to the left.
  14. krayzeesmoke
    krayzeesmoke Member
    Lexington, KY
    I bought some of those mini signals on (cough) eBay (cough) and it only cost me ~$15 mini led lights if you want to same some time, NOT the best (China = 2-3 weeks) wanna save some money ($15 beats $80 all day) Just a thought
  15. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Thank you for that!
  16. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Those of you that have moved/remounted the ignition how hard is it to do?
  17. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    Really really easy. I did extension wires from the headlight bucket so i could put the stock one back on in the future.
  18. 514rabbit
    514rabbit Member
    Montréal, QC
    I am curious if that taillight lights up the license plate as well... anyone knows?
  19. xRedemptionx
    xRedemptionx Member
    Cleveland, Ohio
    what do you mean?
    like the regular light lights up the license plate.... Is that what you mean?
  20. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Hey man I got my kit and going to start putting it on I also ordered those exact lights you recommended as well. Did you have to change any relays or anything or was it just plug and play?
    Also with hooking up the new computer did you use any fuses or just straight to that blue aux power? Does it provide enough?
