Left over connectors doesn't seem right
Discussion in 'XJ Technical Chat' started by Gcxcountrystar1, May 16, 2017.
  1. Gcxcountrystar1
    Gcxcountrystar1 Member
    Hartford, IL 62048
    So I have been changing the main wiring harness on my 1985 xj700x I have a 2 wire connector black and blue on the left hand side of the bike that I can figure out what it goes to.
  2. Gcxcountrystar1
    Hartford, IL 62048
    My old wiring harness didn't have this these 2 relays on them so I am just making sure I need them.
  3. XJ550H
    one is a diode block it controls all the relays and safety relays oil light you will need that
  4. Timbox
    That first pic might be the one that goes to the gas light? Not too sure from that angle, but if it is right behind the tank and close to the top of the air box, that might be it. Check the gas tank and see if it is a m/f ends.
    Dos anyone have the turn signal relay work around for the X bikes? I don't think he has that relay and I am not sure if all the wires that goes to that under tank turn signal delay relay thing is needed to power the rest of the bike? Thanks.
  5. Gcxcountrystar1
    Hartford, IL 62048
    It is not the connector for the the gas tank. I have already located that one and have it labeled. I do not have they relay that connects to the 9 wire connector(believe it's the turn signal starter relay. I have everything plugged in except the 9 wire connector and that blue and black wire connector and have no power to anything
  6. Quixote
    Quixote Active Member
    Victoria, BC, Canada
    According to the wiring diagram in the service manual, blue/yellow stripe and black goes to the sidestand switch. Solid blue with black goes to the fan.
  7. Gcxcountrystar1
    Hartford, IL 62048
    Ok so I just looked at the wiring (put my glasses on) it is blue and yellow strip so inhale figure out what it goes to. Since my bike doesn't have a sidestand switch is the problem no power is going anywhere.
  8. Timbox
    Do you have a wiring diagram from both bikes yet? If your harness has a stand plug in but your bike does not, you will have to bypass some of those things. Make the bike harness think the stand us up all the time.
  9. Gcxcountrystar1
    Hartford, IL 62048
    I have been looking at the diagrams I'm wondering if i jump the wires if it will work
  10. Gcxcountrystar1
    Hartford, IL 62048
    Going to try to find the Starting circuit cutoff relay that's missing. Yamaha dealer says they can't get it . Can't find it on ebay.
  11. Timbox
  12. Gcxcountrystar1
    Hartford, IL 62048
    I ordered it thank you tim
  13. k-moe
    It is supposed to have one.
  14. Timbox
    Helping out is what the forum is all about. :)
    Stumplifter likes this.
