Wanted Left side/#1 carb body 650seca/maximuilding a set of carbs off
Discussion in 'For Sale, Trade/Swap, Wanted' started by joejr2, Apr 20, 2018.
  1. joejr2
    Santa Fe,NM
    Was rebuilding a set of carbs off of an xj seca 650. The PO stripped out the fuel/air mixture
    screw after wedging it in tight. I can't get it out, so I'm looking for a #1 / left side carb body
    in good rebuildable shape. Not burned up or missing a float pivot post. If need be, I'll buy
    all 4 carb bodies in a set. I have all the rest of the carb components. And only need a stripped down body.
    have you tried drilling it and using a #1 easy out? give it a try even if just for the practice of doing it.
  3. joejr2
    Santa Fe,NM
    I got it out but damaged the threads. Do you Know What size tap Would be needed to clean the threads up in the mixture screw seat ?
  4. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    Are they coarse threads or fine threads?
  5. Toomanybikes
    Tsawwassen bc
    I have a set of left hand drill bits that work like magic on those screws. Haven't wrecked one yet.
  6. joe elliff
    joe elliff Active Member
    illinois
    I have no idea if they’re the same size but I have a complete rack for a 750rj available.
  7. XJ550H
    same size bodies just different jets
    Jetfixer and joe elliff like this.
  8. joejr2
    Santa Fe,NM
    fine threads
  9. joejr2
    Santa Fe,NM
    where did you get those bits ?
  10. joejr2
    Santa Fe,NM
    Is that a rack of stripped carb bodies ? or complete cabs ?
  11. joejr2
    Santa Fe,NM
    I found an outside left carburetor on ebay and ordered it last night.
  12. joe elliff
    illinois
    Complete rack
  13. joejr2
    Santa Fe,NM
    The brass mixture screws are a bear to remove compared to the steel ones.
  14. joejr2
    Santa Fe,NM
    does anyone know what diameter , thread pitch, and thread count for the fine thread mixture screws.
    If I could get a machine screw that matches, I could screw it into the few remaining threads, squeeze
    some JB weld in from the top and back the screw out, restoring the threads, kind of.
  15. Polock
    those are 6mm by .5 pitch
  16. Toomanybikes
    Tsawwassen bc
    Princess auto in Canada
    Similar to Harbour Freight in US
  17. Towens
    Towens New Member
    Great Falls, MT
