Long(ish) Term Storage
Discussion in 'XJ Technical Chat' started by eman1974, Dec 4, 2009.
  1. eman1974
    eman1974 Member
    Halifax, NS, Canada
    I'm expecting to be away from my bike for a period of a year starting Feb.
    Between now and when I leave, I will be
    1. Installing a new MAC 4-2 exhaust
    2. Cleaning and rebuilding the carbs
    Is there anything different that I should do other than the usual "Winter Storage" stuff?
  2. bigfitz52
    use Sta-Bil and not SeaFoam as a gas treatment; double up on the usual concentration (as they recommend for just this purpose) and leave it in the carbs.
    Block up the front of the frame so both wheels are off the ground and reduce the tire pressure to about 6-10lbs.
    Use "engine fogging spray" not motor oil in the cylinders, and fog the inside of your new mufflers too.
  3. TIMEtoRIDE
    If you wanted to go a little further, you could overfill the crankcase, smear grease on the fork tubes, spray everything down with WD-40 on metal, and furniture polish on paint, condition the seat, wipe oil on the rotors that you will remove when you rejuvinate the bike, things like that.
    If you get a soup can full of oil and a chip brush, you can dab on to any rust, oxidation, and bare aluminum. A pressure washer will clean things up when needed. Just don't spray too hard.
