Long term storage without front end
Discussion in 'XJ Technical Chat' started by Dan Gardner, Sep 24, 2021.
  1. Dan Gardner
    Minneapolis, MN
    If I wanted to put a bike away for the winter but take off the front forks to be able to work on them over the winter, what would be the best way to do that? The easy way would be to put some sort of stand under the exhaust to hold up the front end, but that seems like a bad idea - a lot of weight on the exhaust for a long time.
    Getting a jack stand under the frame in the area of the oil filter doesn't seem to want to work. Maybe my jack stands are just too fat or something.
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    I don't think weight on the exhaust for a season is any worse than for a day or week, unless the exhaust will corrode over that period and get weaker and weaker. Share the weight with the back tire.
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
    It’ll sit on the center stand without a front end indefinitely. Just have to be mindful that a nudge to the rear will drop it to the floor. Put a jack stand or two on the frame rails if you’re worried.
    Stands on the case guards works too:
  4. Dan Gardner
    Minneapolis, MN
    I will have to try that jack stands under the crash bars trick.
  5. Dan Gardner
    Minneapolis, MN
    I've got an ambitious list of projects for the XJ650J this winter, including:
    Master cylinder rebuild
    Caliper rebuild
    Clean/lube speedo to hopefully fix Mexican jumping bean
    Repaint speedo/tach needles and red zones on the faces
    Fork rebuild
    So I want to put it in storage, pull all the parts off, and have them in the house for the winter, which leaves the bike without any front forks.
  6. k-moe
    Strap the centerstand to the rear wheel frame so the stand can't close.
    Put about 75 pounds of weight on the passenger seat.
    For insurance use a longish peice of wood on the oil pan, and set a jackstand under it.
    Do not allow the exhaust bear any weight.
  7. Dan Gardner
    Minneapolis, MN
    OK, thanks everybody. Some good ideas. I will work on it.
  8. Franz
    You can fix a strong rope from the centrestand to the front transverse frame rail to stop it shutting.
  9. JCH
    JCH Active Member
    seattle wash
    I install a 1 inch by 2 inch about 5 inch long piece of lumber in-between exhaust pipes 2 and 3 on the frame rail with a car screw jack.
  10. hogfiddles
    I’d strap to the FRONT
    Minimutly and k-moe like this.
  11. k-moe
    I edited my response. Brain farts happen.
  12. Dan Gardner
    Minneapolis, MN
    I gave it a test run and I think I should be able to do like @jayrodoh did and put my crappy jackstands under the crash bars, along with a ratchet strap from the center stand to the crash bars.
    JCH and jayrodoh like this.
  13. kosel
    MInneapolis, MN
    When I took off my front end, I used a large chink of styrofoam I got at the recycling center. Easily cuts down to whatever height you need and it was soft enough that it formed around all the pipes and curves and corners without marring paint or anything.
  14. Dan Gardner
    Minneapolis, MN
    Finally had to put it away for the winter. Here's how it ended up - sitting on the jack stands under the crash bars, and a ratchet strap from the top for insurance:
    Franz and jayrodoh like this.
