Look ma: no carbs!
Discussion in 'XJ Modifications' started by SQLGuy, Jun 7, 2008.
  1. Ease
    Ease Member
    NL, Canada
    There's a pic of the flasher on pg 8 of my thread too... (see link in my sig)
  2. SQLGuy
    SQLGuy Well-Known Member
    I looked at that before, but I didn't see anything about the self-cancelling functionality. Does yours work with the stock self-cancelling circuit?
    Just to re-cap, what I was talking about here was that I converted to LED turn signals, without load resistors, and built a new flasher circuit that works correctly with these turn signals and still supports the stock auto-cancel system (time and distance based).
  3. tomandjerry00
    tomandjerry00 Member
    Washington DC/Philadelphia
    That is the most incredible mod I've ever seen to any 80's motorcycle...
  4. schmauster920
    schmauster920 Member
    Ventura, CA
    Love the EFI, i would love to do this, along with a turbo :D
    Have you considered using a non heated 1 wire oxygen sensor for less electrical drain?
    I have a wideband in my bike (too bad you werent closer or i could have let you use it and saved you some cash at the dyno)
    http://www.xjbikes.com/Forums/viewtopic ... tml#147297
    If i leave it on, the whole header pipe gets hot, so im sure its drawing quite a bit of power for the heater.
  5. bunglejyme
    bunglejyme Member
    New Jersey
    I've always wondered about replacing those %#$@*^& Hitachi carbs on my Xj650H.
  6. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    Absolutely beautiful.
    I so wish I could do that.
  7. Decapitated_Toy
    Decapitated_Toy Member
    burlington, wa
    a tip of the hat to you..... great work.
  8. rightwinger
    rightwinger New Member
    St. Louis Missouri
    I was looking at your pic, and I thought thats what that was. Good job!
    I wonder if a single carb (for us poor folk) is a possible setup.
  9. chuckles_no
    chuckles_no Member
    wisconsin
    Was wondering how things are going with this project. Hoping the reason for the deleted pics and other project links are due to a possible patenting project. There are loads of people on these bikes, hondas, kawasakis, etc that would love to convert. Anyway, how are things?
  10. koolaid5
    koolaid5 Member
    Chambersburg, PA
    +1
    I was reading this thread and wondering what heppened with it as well....
  11. 82secaturbo
    82secaturbo Member
    i am truly chomping at the bit tp hear how things are with the FI setup? I just got a sECA Turbo and was looking to add auxillary injectors for more fuel under high boost, but a full on injector swap sounds even better.
  12. Hzleyes63
    Hzleyes63 New Member
    Belleville, IL
    I would love to see pictures of your accomplishment. I would definitely convert my 82' XJ 750 to fuel injection.
  13. jeepsteve92xj
    jeepsteve92xj Member
    Milwaukee, WI USA
    GAH!
    I popped in to reread this project, and all the pics are gone and the link is no more.
    Has anyone heard from SQLGuy ?
