Looking for new carb jets
Discussion in 'XJ Technical Chat' started by Ilydev0, Oct 15, 2025.
  1. Ilydev0
    Ilydev0 New Member
    So I recently removed my air box and installed pod filters and modified my exhaust now the bike wont start at all , figured id have to buy new jets any recommendations where to get some good ones from ?
  2. Franz
    Welcome to the forum. Len aka chacal sells lots of parts for XJ owners here. You can email him on info@xj4ever.com and checkout the parts for your bike by clicking on the XJ4ever logo on the top right of your screen.
    Timbox likes this.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Welcome, but a word of caution - replacing the exhaust will not stop your bike starting due to needing rejetting - you have another issue.
    Oh poo, misread, so you removed your airbox as well - stand by for some major "you don't wanna do that".
    My answer is the same, but to a lesser degree, no airbox and a different exhaust won't stop it running from cold. Make sure the PRI is working on the petcock...
    Brhatweed, Ilydev0 and Huntchuks like this.
  4. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Pods should not prevent starting also.
  5. Ilydev0
    Ilydev0 New Member
    I have no idea why this darn bike wont start then
  6. Rooster53
    Battery condition? Check while cranking should stay above 10V, anything lower and spark will be too weak
  7. Ilydev0
    Ilydev0 New Member
    Battery is brand new , timing possibly?
  8. Secacsm89
    Secacsm89 Member
    Jetsrus.com will hook you up.
  9. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    I've worked with Jets-R-Us in the past, reasonable but make sure your address is correct if you're using PayPal... found out the hard way they will only ship to that listed address and lost a set of jets because PayPal didn't update despite making the changes when I moved.
    If you can't get it started after cutting the airbox up and modding the exhaust the problem is not jetting... this is only the start of your tuning nightmare.
  10. Minimutly
    West Wales, uk
    And if you can't work out why an engine won't start there is little hope of you getting it anywhere right on pods and 4 to 1...
    Seeing as it's been 3 months since the op last seen I guess this post is for others as well as the OP, if he comes back..
    Brhatweed likes this.
