Looking for piston rings for XJ 400 SE 4v7, 4v8, 4g0, 4 cylinders
Discussion in 'XJ Technical Chat' started by Hamcho, Apr 16, 2026.
  1. Hamcho
    Hamcho New Member
    Macedonia
    It's hard to find the exact OEM Number but I narrowed down that I need (Please confirm if these numbers are match for the XJ 400 SE)
    OEM:
    ~4G0-11610-00
    Aftermarket:
    11-Y4G0PR
    I am from Macedonia so it's almost impossible to find OEM parts. Can anyone more experience confirm if the aftermarket parts would do the job or anything else I can use inst4ead? Thank you in advance
  2. Hamcho
    Hamcho New Member
    Macedonia
    Update: Messured the bore with the Vernier caliper, it was reading 50mm(not sure if I read id right since I couldn't find anything about 50mm pistons). Ordered the 51mm 11-Y4G0PR from cruzinimage. Honed the bores, redid the valves, main bearings looking good. I will use headgasket from XJ550, need to wait 2-3 weeks for the piston rings to arrive.
    cds1984 likes this.
