Looking to buy, any problems I should be weary of?
Discussion in 'XJ Technical Chat' started by ratboy, Jan 23, 2019.
  1. ratboy
    ratboy New Member
    I'm looking to buy a 1983 maxim 650, are there any specific problems I should look for before buying? Stuff that's known to go wrong on these bikes (eg. starter clutch issues on Viragos)?
  2. a100man
    a100man Well-Known Member
    Bedford, UK
    Make sure it starts (from cold), idles Ok, doesn't smoke too much and you can select all gears - shaft XJs apparently have some primary drive tensioner that breaks up and jams the gear box.. All standard stuff to be honest.
    ratboy, Franz and k-moe like this.
  3. k-moe
    The starter clutch and the alternator chain guide are the ony weak points. Both require a case split to remedy, but once done both will be good for another 20 to 30 years. A slipping starter clutch is not necessaraly indicative of the clutch failing though.
    ratboy and Franz like this.
