Lost half my electrical
Discussion in 'XJ Technical Chat' started by Colin 85 700, Aug 17, 2021.
  1. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Out riding today and randomly lost my tach... no warning.
    I stopped and realized I had no neutral light.
    Upon closer inspection I noticed I had no horn, signals, or brake lights either.
    I have running lights, hi low beam, fuse appears good.
    Any direction to start in before I test every wire on the bike would be great.
    Thanks in advance for all the great help and suggestions.
  2. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    How is the fuse box itself? I had to replace mine all the fuses were good but the clips were bad under the fuses.
  3. Colin 85 700
    Thunder Bay, ON
    Fuse box? I found the main under the seat.. pulled side panels... had the bike apart from paint... why don't I remember a fuse box...
    I feel like an idiot right now...
  4. Franz
    If it's the original fuse box the clips break. Better with a blade type fuse box.
  5. Rooster53
    If we are talking 85 XJ700 in your signature you won't find a fuse box as they are mounted under the indicator light panel with the exception of the main. The Flasher fuse would be the suspect fuse that powers the circuits that you mentioned were not working.
    Colin 85 700 and Franz like this.
  6. Uxbridge Brule
    Uxbridge Ont
    Not the type of fuse box I was thinking of but that's what's great about this site, ask for help and it gets the ball rolling.
    Colin 85 700 likes this.
  7. Colin 85 700
    Thunder Bay, ON
    Hence why I didn't see a fuse box!
    I feel less like an idiot!
    Thanks Rooster I'll keep posted!
    Uxbridge Brule likes this.
  8. Colin 85 700
    Thunder Bay, ON
    Yup! Was the one on the left!
    Used the spare, just gotta remember to replace it!
    Thanks again! Didn't know they were there!
  9. k-moe
    Now the thing to do is figure out why the fluse blew. Start looking for worn insulation around the steering head.
