For Sale Lots of parts available 550/650/750.....Maxim and Seca
Discussion in 'For Sale, Trade/Swap, Wanted' started by hogfiddles, Jul 30, 2018.
  1. Jetfixer
    SECA 750 gas tank ?
  2. hogfiddles
    You need one?
  3. Jetfixer
    Yes ,I have one that is really beat up . Have my 100$ Seca it is missing the tank.
  4. Kerry Krick
    Kerry Krick New Member
    Michigan
    82 Maxim xj750 front turn signals if you have them.
  5. hogfiddles
    Black rectangular ones...... I’ll see what I got.
  6. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    I believe they are chrome dave.
  7. hogfiddles
    Oh, duh-I was thinking of the 750 seca ones.... yeah the ‘82 750 maxim ones are like the 550 seca ones....
    still looking.......
  8. hogfiddles
    Kerry, yep- I have a set... just gotta pull them off and clean them up.
    front
    Back
    Dave Fox
  9. hogfiddles
    I MIGHT have one yet..... I’ll look around.
    Spduffee likes this.
  10. hogfiddles
    No problem Kerry, since you haven’t checked back in at all since you became a member and made a “parts wanted” post, Obviously you don’t really need them.....I’ll just put these back into inventory.
    dfox
  11. hogfiddles
    Since you haven’t replied at all, I’m putting it back in the engine so I don’t lose it.
  12. Doug M
    Doug M New Member
    I have a xj700 (I know that this post was for 550-650-750), but cant hurt to ask. I am looking for the rubber "boot" that goes on the end of the spark plug cap, just need one. Thanks, Doug
  13. hogfiddles
    I kn0w what I have to look for…..but I need weather to cooperate just a bit so I can get out there and look. I’ll try to make a point of it this weekend,
    dfox
  14. hogfiddles
    Doug, on the 700 it’s pretty much the same thing as the others, are you looking for a boot for a 700 aircooled, or are you looking for the boot for an X……THOSE are a longer orange rubber boot since the plug is down in a well.
    dfox
  15. Doug M
    Doug M New Member
    700 aircooled. 85 N model. Not in a huge rush, so no problem if it takes you a while to get through the snow... Thank you.
  16. hogfiddles
    I’ll look this weekend
  17. scoobydew
    scoobydew Member
    new york
    Hi,
    Would you happen to have a RH side cover panel for the XJ750?
  18. hogfiddles
    Maxim or Seca?
  19. scoobydew
    scoobydew Member
    new york
    1982 XJ750 Seca
  20. hogfiddles
    I’ll look...but I think the only right Side ones I have are missing tabs
  21. Dan Gardner
    Minneapolis, MN
    @hogfiddles if you have one that is at least salvageable I could fix it for @scoobydew
    I might have one that is in need of repair in the queue if you don't have one.
  22. hogfiddles
    Only ones I have right now are a couple left side ones:(
  23. scoobydew
    scoobydew Member
    new york
    :( oh man, yea I have a RH side cover panel but the tab that fits into the tank is missing so I've been looking for one.
    There's tons of LH cover panels on Ebay but no RH cover panels... must be pretty rare
    I appreciate any help. I do have a RH cover panel, but the tab was missing so the PO fashioned a homemade tab out of a toothbrush handle and stuck it to the cover panel but it doesn't fit snug into the tank grommet :(
  24. Dan Gardner
    Minneapolis, MN
    @scoobydew - If you'd like, I could attempt a repair. PM me.
    Whatever you do, please don't throw it away.
  25. hogfiddles
    Often people drill a shallow hole, thread in a bolt,the build it up with plastic, abs cement, etc…. To form new bullet. Build the toothbrush part thicker and the re-shape.
    I believe there are some tutorials in the forums here too——me just haven’t seen them in a long time.
    Dan’s right— DO NOT throw them out….
  26. lawnmower man
    lawnmower man New Member
    michigan
    i know your post is old but do you have a muffler for a 1982 xj 750 thanks
  27. hogfiddles
    Duffee....... I sent a reply a long time ago, maybe it didn’t go through—-don’t have e one right now
    lawnmower—maxim or Seca?
  28. lawnmower man
    michigan
    maxim
  29. hogfiddles
    I’ll look...
  30. Door dude
    left or right side? I have a left for a maxim.
  31. lawnmower man
    michigan
    if your sitting on the bike left side maxim 750
  32. lawnmower man
    michigan
    left side
  33. Door dude
    if you wish i can im pictures, it's not perfect.
  34. Noahsxj
    Noahsxj Active Member
    SW Missouri
    Possibly a project xj900?
  35. hogfiddles
    Not too sure if I wantto give any up yet, but let me think about that for a bit…….
  36. Noahsxj
    SW Missouri
    I’ll take your roughest one, as long as it’s at least semi there
    can get a lot of parts from German eBay, and it won’t get chopped
    I still have plenty of none bike related projects that I have to finish first but definitely let me know
  37. hogfiddles
    Send me a private conversation, and we can stay in touch. I’ll give you my contact information that way,
    dfox
  38. Motown
    Motown New Member
    Michigan
    You wouldn't happen to have a side stand safety switch for an 82 XJ750 Seca would you? The PO on mine pulled the wires. I pulled the switch and cleaned it up
    and was talking with Len about rewiring it first to see if it still functioned. So the plan is to do that first, but working on my backup plan.
    Here's what mine looks like and the wiring I need to hook up (thanks Len)
    I also have moldable plastic to seal it in when I am done.
    Your wire colors are basically correct, and they will be oriented into the connector
    shell as follows………..NOTE that these orientations are as viewed from the
    rear side of the connector shell
    (where the wire enters the shell):
    (latch up here)
    X1 X2
    X3
    X1 = blue wire
    X2 = green wire
    X3 = black wire
    Thanks Motown
  39. hogfiddles
    I’ll look through ... I have several different ones
  40. Austen McAllorum
    Austen McAllorum New Member
    Delta,Bc,Canada
    I’m looking for the headlight rectifier diode and headlight reley if you have working parts for both I’m. Sure we can negotiate a price cheers
  41. ToxicManchild
    ToxicManchild New Member
    New York
    I might be looking for a 750 seca motor. Got one?
  42. hogfiddles
    Any ‘81-83 xj750 engine will work…..Maxim or Seca. If you use a Maxim engine, you just need to make sure you use the seca engine mounts, and you may need to swap the shifter cover.
    I’ll check to see if I have any extra 750 engines……. I know I have several engines, but just not sure what cc at the moment.
    Dave Fox
  43. ToxicManchild
    New York
    Thanks for taking a look at least. Tearing down a motor right now that may not be salvageable so I'd like to know my options. eBay wants 600$ and that's just a bit too rich for my blood
  44. VAN1SH3D
    VAN1SH3D New Member
    Gillett
    Do you have a set of carbs to fit a 1985 maxim 700 I do believe, the title says the model code is an XJO 700cc. I do know it has the yics motor on it and i have a set of carbs for a non yics maxim 650/750 carbs but they won’t fit 1F9CD4E1-9DAE-447C-A45A-9FFB2E8DCFF3.png 285917B3-6506-448A-94F1-970CE392B953.jpeg
  45. hogfiddles
    Corrrct—- the 650/750 carbs are a different size.
    I don’t have any available right at the moment.... I’m rebuilding a set for someone right now and already cannibalizing my extra set. When I’m done, then I’ll know what I need to get to to re-complete THAT set...... but it won’t be quick. I’m semi-incapacitated with a tough case of sciatica at the moment, so moving real slow
  46. VAN1SH3D
    VAN1SH3D New Member
    Gillett
    Ok I appreciate it and if you have even a set that’s bare that’s needs a full rebuild I can do a rebuild kit for them I’m just trying to go ride with this bike at the Elmira pride ride the 14th
  47. michael moberg
    michael moberg Member
    vallejo, california
    I have top end , off a 82 750 maxim.....
  48. joejr2
    Santa Fe,NM
    I need an 81-83 plastic headlamp bucket for an 81-83 xj750 rh seca
  49. hogfiddles
    Don’t got one right now
  50. BuyersRemorse69
    BuyersRemorse69 New Member
    New York, USA
    Wouldn't happen to have a spare 550 seca tank? I'd trade you a 550 maxim tank if you want with cash.
