For Sale Lots of parts available 550/650/750.....Maxim and Seca
Discussion in 'For Sale, Trade/Swap, Wanted' started by hogfiddles, Jul 30, 2018.
  1. Jake Bane
    Jake Bane New Member
    British Columbia, Canada
    Stare circuit cut-off relay? Tried to google and tried the haynes manual but can't seem to find anything about it. The project bike i got was missing one so can't google a part number. Anything and everything electrical: CDI unit, reg/rec, fuse box, even the plastic board that the cdi and reg/rec attach to (all the tabs on mine are snapped off), wiring harness (mine has all sorts of plugs cut off and random bodge jobs all over), ignition coils, elbow connectors, flasher relay, starter switch (handlebar). Whoever had this bike before me did a real number on it.
  2. hogfiddles
    Wow. I’ll look through stuff.
    Where are you located?
  3. Kurtis Scotti
    Kurtis Scotti New Member
    New Jersey, United States
    Hey hogfiddles! I’m trying to track down an air duct for my ‘86 XJ700 airhead. Any chance you have one sitting around ?
  4. Jake Bane
    Yeahhh, I think the main things would be starter circuit cut off relay and possibly flasher relay. I can probably sort most other things out with enough dedication but replacement parts would be preferable.
    I’m in British Columbia, Canada, but I’m happy to cover shipping costs if you find some good stuff lying around
  5. Aaron Robbs
    Aaron Robbs New Member
    NSW
    Hi mate I’m after a headlight plus the housing for Xj 550. I’m in nsw
  6. hogfiddles
    Maxim or Seca?
  7. Aurel
    Aurel Member
    Texas
    Hey, do you have any piston housing for 750rh yics? With sleeves in good condition?
  8. hogfiddles
    I’ll assume you mean the cylinder block?
  9. Aurel
    Aurel Member
    Texas
    Yes sorry! I'm new to this
  10. hogfiddles
    I’ll look.
    Aurel likes this.
  11. GreaseWeasel
    GreaseWeasel New Member
    Pennsylvania
    Hello! Hope you're well. Just wondering if you happen to have a 5 spoke rear wheel for an xj700s. One of the ones that looks like the front but more squat. Thanks for your time!
  12. hogfiddles
    I’m sure I do. I’ll check today
  13. hogfiddles
    Yep, I have a couple
  14. Mason Eyler
    Mason Eyler New Member
    Pennsylvania
    Looking for a 1980 or similar XJ650 frame with title. Do you have anything?
  15. hogfiddles
    I don’t think so...... but I’ll look
  16. 7.62
    7.62 New Member
    California
    Looking for a trip meter knob for an '81 XJ650 Maxim. Got any busted speedos you can scavenge one off of?
    Not at the moment
  17. hogfiddles
    I’ll look
  18. nablats
    nablats Member
    whitby
    Hi, I am after pickup coils for 1982 xj650 (uk)
  19. hogfiddles
    Any 1980-1983 xj650 and Xj750 Maxim/Seca coils interchange
  20. VAN1SH3D
    VAN1SH3D New Member
    Gillett
    Do you happen to have a y-23 needle and a y-22 needle for the carb slide
  21. hogfiddles
    Nope....
  22. hogfiddles
    Not at the moment, sorry
  23. hogfiddles
    Nope.... those are for Virago’s
  24. hogfiddles
    Like I said earlier, yup I have a couple.
  25. 7.62
    7.62 New Member
    California
    No problem Dave, I appreciate that you took the time to look. Thanks.
  26. hogfiddles
    I’ll keep an eye out
  27. Soup
    Soup New Member
    Mississauga ontario
    Looking for a carb setup for a '80 650. Any chance you have?
  28. Balloo
    Balloo New Member
    Ontario, Canada
    Looking for oem mufflers for an 83 seca 550
  29. 750MaximSeattle
    750MaximSeattle Active Member
    Seattle, WA
    Seeking parts for 1982 xj650 Maxim I'm restoring, with low-budget constraint this time around:
    RH tank emblem
    LH emblem too if it's nicer than the "crusty" one I have (see attached)
    Fork emblem if the chrome is good, to replace the one I have which is primer black.
  30. hogfiddles
    Hey:) been a long time!
    I’ll see what I got.
    dave fox
  31. chacal
    Hey Seattle, that sure is a nice-looking bike for a "low-budget" resto!
  32. Franz
    Nice Bike.
  33. Trkdrvr
    Trkdrvr Member
    New Hampshire
  34. Trkdrvr
    Trkdrvr Member
    New Hampshire
    Maybe this will help with your tank emblem search.
    I started this barn find in may 24
    Rattle can paint and found emblems on eBay 11.00$ only catch is they were stick on,
    So I had to drill them out myself.
    I can try to search if you would like.
    Good luck with your project
  35. minimuttly
    minimuttly Active Member
    UK
    Hi @hogfiddles . My xj650 Seca build back is lacking a pair of grab handles - I think they were chrome, just under the seat? Got a pair? It will mean posting to the UK so if you don't want the hassle I will understand.
    PM me @minimuttly if you want.
  36. hogfiddles
    I’m not sure if I have extras or not—- I’ll look.
    in the meantime, they’re are shared with the xj650 (European).......also, Len carries reproductions, too—-
  37. Maxim3
    Maxim3 New Member
    Moore, OK, U.S.A.
    How about a stator coil and cover for 86 XJ700X?
  38. hogfiddles
    I’ll look
  39. hogfiddles
    Nope don’t have any extra handles at the moment.
    minimuttly likes this.
  40. Xander S
    Xander S Member
    Missouri
    Recently my younger brother crashed my 1983 xj750 maxim into a ditch (he is doing ok), and the entire right side of the bike is destroyed. (Motor is still fine thankfully)
    I was wondering if you had any of these items for sale:
    • Front Brake Master Cylinder and Lever
    • Gas Tank
    • Gauge Cluster (Tachometer got completely destroyed, so I'll need an exact replacement)
    • Rear Grab Bar (Just the bit covered in the rubber material)
  41. hogfiddles
    With a bit that hard, first check to make sure the frame isn’t bent.
  42. shotgunsmitty
    shotgunsmitty New Member
    North Carolina
    Igniter, maybe? For an XJ650RJ?
  43. Xander S
    Xander S Member
    Missouri
    It ended up flipping completely and flattening the handlebar, tank, gauges and grab bar. I haven’t seen any frame damage or warps, so I think the frame is still in good condition, I just can’t ride it until I find some parts
  44. ourygrip
    ourygrip New Member
    Atlanta, GA
    Hello. Do you have any windscreens for the Seca 750 touring fairing? Thank you.
  45. minimuttly
    UK
    Thanks for looking
  46. hogfiddles
    No, sorry.
    Talk with Len at xj4ever
  47. Al2023
    Al2023 New Member
    Vaughan, Canada
    Hi Dave,
    This is probably a longshot, I was wondering if you have the 1982 XJ650 maxim engine or similar that I can swap mine into.
    Al
  48. hogfiddles
    You want to swap something into the engine? Anything in an ‘82-83 650 maxim engine with fit in another ‘82-‘83 650 maxim engine. Most ‘80-81 parts will, too, but there are some differences.
    do you mean “do I have any ‘82-83 engines? “. Yes, probably do.
    Let me know what you mean, and I’ll look.
    Dfox
  49. 4nik8r
    4nik8r Active Member
    Ottawa, ON, Canada
    Other than the cams, what are the differences between a seca and maxim 550 engine, exactly? After 115,000 km, I'm having issues with my seca engine but have a line on a maxim 550 engine, plus I have another 550 seca engine but with damaged heads and damaged cylinders. I read somewhere that the maxim engine has a lower compression ratio, is that true? Are maxim and seca heads the same with the only difference being cams, or is a maxim head, valve train and/or pistons all different to account for the compression ratio difference?
  50. hogfiddles
    NOTE: in the truest hot-rod tradition, people sometimes inquire as to camshaft specifications and interchange. We have compiled the following information for your reading pleasure:
    XJ550 Maxim:
    Intake Lift: 6.80mm
    Exhaust Lift: 6.80mm
    Duration: not given
    Overlap: not given
    XJ550 Seca:
    Intake Lift: 7.80mm
    Exhaust Lift: 7.10mm
    Duration: not given
    Overlap: not given
    a) XJ550 Maxim and Seca cams can be swapped between these engines (but not with any of the 650-up engines). The 550 Seca cams are "hotter", they have more lift, and probably also have increased duration and possibly overlap.
    Here are all the different stock carb specs (carb model numbers, jet sizes, tune-up info, etc.) consolidated into one happy little group of information, so you can print this out easily when you are working on your particular set.
    XJ550 Models:
    Years & Models: 1981-83 XJ550 Maxim North American models
    Carb Manufacturer: Mikuni
    Carb Series: BS28
    Carb Model ID: 5K500
    Main FUEL Jet Size: #112.5
    Pilot FUEL Jet Size: #35
    Main AIR Jet Size: #70 (non-removable, in carb throat)
    Pilot AIR Jet Size: #165
    AIR COMPENSATOR Jet Size: not used.
    Starter FUEL Jet Size: #35 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4GN
    Main needle JET Size: #O-8 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 2mm +/- 1mm (.08" +/- .039")
    Idle RPM's: 1,200 rpms
    Vacuum reading at idle: not specified
    Vacuum, allowable difference between cylinders, at idle: not given
    Although not part of your carbs, your valve clearances should be considered as part of your "intake system", so here are those specs, too. Note that valve clearances should be measured with the engine "cold", meaning 70-degrees Fahrenheit or less:
    Valve Clearance Intake: 0.11 - 0.15mm ( = 0.004 - 0.006")
    Valve Clearance Exhaust: 0.16 - 0.20mm (= 0.006 - 0.008")
    Years & Models: 1981-83 XJ550 Seca North American models
    Carb Series: BS28
    Carb Model ID: 4U800
    Pilot AIR Jet Size: #170
    Main jet NEEDLE ID: #4GZ11
    Years & Models: 1981-83 XJ550 Euro models
    Carb Series: BS28
    Carb Model ID: 4U900
    Pilot FUEL Jet Size: #37.5
    Main jet NEEDLE ID: #4GZ3
    Years & Models: 1984 XJ550L Maxim models
    Carb Series: BS32
    Main FUEL Jet Size: #105 (cylinders #1 & 2)
    Main FUEL Jet Size: #102.5 (cylinders #3 & 4)
    Pilot FUEL Jet Size: #40
    Pilot AIR Jet Size: #155
    Starter FUEL Jet Size: #42.5 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4CP7-3 (cylinder #2)
    Main jet NEEDLE ID: #4CP3-3 (cylinders #1, 3, and 4)
    Main needle JET Size: #N-8 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    All this and more can be found in The Information Overload Hour:D
    dfox
    Fuller56 likes this.
