lower headlight
Discussion in 'XJ Technical Chat' started by twinky, Jun 6, 2017.
  1. twinky
    twinky Member
    twinkville
    Ok..... my headlight relay switch on my Seca 750 isn't working so i jumped it with a wire and added a toggle. can i do the same thing with the lower light?
    while it is not advised you can do it
  3. Rooster53
    You should already have a toggle for the Auxiliary (Fog light), it is located on the right control.
    Agree, headlight relays are cheap and you won't need to worry about remembering to turn it on as a day time driving light for added safety, or to turn it off to reduce the load on the battery at startup.
  5. Polock
    it has it's own switch, you might cook some wires if you use the headlight wires
  6. twinky
    twinky Member
    twinkville
    ok, thanks...
