Main Air and Pilot Air size
Discussion in 'XJ Technical Chat' started by Arron Tate, Jun 29, 2020.
  1. Arron Tate
    Arron Tate New Member
    Space
    Hello All,
    Newbie here :)
    Can anyone provide the size of the following jets.
    Jet, Pilot Air = 4H7-14949-45-00
    Jet, Main Air = 4H7-14928-16-00
    The numbers stamped on then are so lite / distorted there not readable.
    1982 XJ750RJ
    Thanks in advance,
    Stay Safe......
    Arron
    from this link http://xjbikes.wikidot.com/carb-specs
    if it is a canada bike jets are different check above link
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 15R00 (Maxim, Midnight Maxim)
    Carb Model ID: 5G200 (Seca)
    Main FUEL Jet Size: #120
    Pilot FUEL Jet Size: #40
    Main AIR Jet Size: #80
    Pilot AIR Jet Size: #225
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-13
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    Idle RPM's: 1,050 rpms
  3. XJ550H
    if you are replacing them chacal will have them he is our supporting vendor www.xj4ever.com
  4. Arron Tate
    Space
    Hello XJ550H,
    Thanks for the info.
    And yes its a USA 750 Saga.
    Thanks for providing the name of a vendor for replacement jets.
    Sorry but I am still learning my way around this site.
    I did find the xj4forver web page on line.
    Stay Safe......
    Arron
  5. XJ550H
    his logo in the upper right corner can be clicked, and then a conversation started with chacal about your purchase. I go through his web site .
  6. Arron Tate
    Space
    Hello XJ550H,
    Is there a place that I can find the instructions for how to bled the front brakes.
    Bike has the two calipers and the valving on both forks for the anti dive / brake system.
    82 XJ750 Seca
    Stay Safe......
    Arron
  7. XJ550H
  8. Arron Tate
    Space
    Hello XJ550H,
    Stay Safe......
    Arron
