Master cylinder rebuild (need help)
Discussion in 'XJ Technical Chat' started by som1somwhere, Jul 13, 2013.
  1. som1somwhere
    som1somwhere Member
    United States, Illinois
    http://i.imgur.com/LIkM5Sb.jpg?2
    Ok which way are the seals supposed to go on? i have tried 2 different ways that i thought were correct and they turned out not to be.. first one was the smaller side of the taper on both pointing towards the spring and now the one in the picture... could really use some help because the master cylinder and acting like it won't pump like it should and this is a new rebuild kit
  2. adrian1
    adrian1 Active Member
    Thats correct. Flared larger OD towards the fluid. Bleeding a system after disassembly on these can be difficult. See other recent threads about difficult bleeding.
  3. som1somwhere
    som1somwhere Member
    i bled out all i could tonight and it's 3am here so... no more air was coming out but it still wasnt stiff so i went ahead and zip tied the handle back a little and now imma let it sit over night and see what it does
