Max-xj700x Refurb
Discussion in 'XJ Technical Chat' started by Max 700-X, Feb 24, 2021.
  1. Max 700-X
    Max 700-X Member
    AL
    Figured, while the coils and bracket were out of the way, I'd take the valve cover off, spray it and polish the hold-down bolts. Also took the petcock from the parts bike and disassembled for cleaning. The one on this bike was a non-vacuum replacement and one of the previous owners ran a screw down the number 2 intake vacuum cap.
  2. hogfiddles
    Personally, I DONT like the look of pods.
  3. Max 700-X
    Max 700-X Member
    AL
    I'm not a big fan of the generic designs but, in my opinion, the K&N or DNA oval filters (when clean) look good.
    I have considered velocity stacks with a RAMAIR filter to promote laminar flow to the carb inlet, but I'll probably stick with the airbox.
  4. Max 700-X
    Max 700-X Member
    AL
    Just a progress pic. Reinstalled the painted rear fender with new brake light and blinkers added, I two-toned the side grab bars to highlight the Maxim name. Grabbed the side cover from my parts bike and painted it to match the metallic grey/black theme. Exhaust outlet has been prepped, sprayed with high temp paint and I'll attempt a wrinkle finish top coat. After that, reinstalling the coils and plugs.
    Franz and chacal like this.
  5. Toyobaru866
    Toyobaru866 Active Member
    Netherlands
    I try to keep mine as stock as possible but must admit that grab bars look pretty slick.
  6. Max 700-X
    Max 700-X Member
    AL
    Thanks 866, I bought the bike earlier this year and someone had spray-bombed a lot of it black at some point. It left a lot to be desired...the only part that had any color was the radiator cover which was sprayed with, what I can only call, 'zombie green'!
    I really like the look of the bike, so I won't be doing anything drastic. However I can see some opportunity for small aesthetic improvements and the silver and metallic grey compliments well.
  7. Dan Gardner
    Minneapolis, MN
    Looking real nice!
  8. XJ550H
    paint is removable
  9. Toyobaru866
    Netherlands
    True!
    XJ550H likes this.
  10. Max 700-X
    Max 700-X Member
    AL
    It's alive! After many hours of troubleshooting, rebuilding plug caps, replacing coils and addressing the carbs, the X fired up today and ran on its own. I still need to fine tune the carbs, address the charging issue, adjust the clutch cable etc.....but definitely progress.
  11. Toyobaru866
    Netherlands
    Congrats and enjoy!
  12. Max 700-X
    Max 700-X Member
    AL
    Thanks, still have a ways to go but it was a nice day for a picture. (it's come a long way in a short time)
  13. Toyobaru866
    Netherlands
    I like the black concept, thought about doing this to one of my previous X's. Actually 2 part bikes that I wanted to merge into one good bike. Never got it of the ground due to lack of time and ended op selling them... Seeing your project makes me regret
  14. Max 700-X
    Max 700-X Member
    AL
    Thanks for the compliments, mine didn't have original paint left, so it made the decision easy to paint it the color I liked.
  15. Max 700-X
    Max 700-X Member
    AL
    Now that I got the carbs reinstalled and the engine running, I m trying to tackle the non-charging issue. I swapped out the rectifier, hoping for a quick win, but no such luck.
    A previous owner attached each wire into the rectifier harness using spade connectors. I have a total of seven wires from the bike going into the rectifier harness (four on one side, and three on the other). Since swapping rectifiers didn't work, I decided to pull the stator cover off. The attached picture shows what I have. As you can see, it's been tinkered with before. The brushes inside look fairly new and its harness looks decent, but the three white wires (going to the rectifier harness) need troubleshooting.
    First, is there a way to check these white wires to see if good?
    Secondly, does anyone have a diagram of the wiring harness that plugs into the rectifier so I can see if a previous owner even had them wired correctly?
    -So far, nothing has been an easy fix. Thanks
      File size:
      343.4 KB
  16. Toyobaru866
    Netherlands
    Hope this can help.
  17. Toyobaru866
    Netherlands
    Forgot those.
  18. Toyobaru866
    Netherlands
    I hope I'm not violating any law or forum rules by posting these pages...
  19. Max 700-X
    Max 700-X Member
    AL
    Great information 866, the testing procedures and specs were very helpful.
    So I removed the wire extension someone added to the stator coil, cut back to good wire on all white wires and added new connectors and shrink tubing. I then retested and got the following readings:
    W1 - W2=.4 Ohms
    W1 - W3=.5 Ohms
    W2 - W3=.4 Ohms
    Later today I will clean and test the field coil. Thanks again!!
  20. Toyobaru866
    Netherlands
    Glad I could help you!
  21. Max 700-X
    Max 700-X Member
    AL
    It certainly did, it even provided the way for me to test the diodes in the original rectifier....which tested good. Hopefully the fix is either a bad connection/loose wire somewhere. I still need to clean/test the field coil....
  22. Max 700-X
    Max 700-X Member
    AL
    Field coil cleaned and tested good at 3.9 - 4.0 Ohms, however while looking at the wires going to the battery, I found a brown wire attached to the negative terminal but just hanging loose on the other end.
    Things that make you go "hmmm"
  23. Toyobaru866
    Netherlands
    Doesn't make you happy... Electronics aren't really my thing, looks like someone has been messing around...
  24. Max 700-X
    Max 700-X Member
    AL
    Victory! After disassembly, cleaning, wiring repair, testing and reassembly, I having a working charging system on Max.
    The bike has been starting well, all cylinders are firing, and I'm no longer working just off the battery. Now I need to lubricate the clutch cable and adjust accordingly.
    Toyobaru866 likes this.
  25. Max 700-X
    Max 700-X Member
    AL
    I also want to look into the fan switch upgrade that turns it on sooner.
  26. Toyobaru866
    Netherlands
    Congrats, must be a good feeling!
  27. Max 700-X
    Max 700-X Member
    AL
    So after getting the charging system operational again, I got the battery box, battery and wires all neatly back in place. Let the bike run to get some temp in the engine and tested voltage again; all good. However, up until now I always turned the bike off before the temp gauge got to the red, but after reading some past threads it appears the fan doesn't cut on until the needle is in the red zone.
    Well, my fan didn't come on, so now I'm troubleshooting this fan issue. I found both wires to the thermoswitch (brown and blue) and tested. With the key on, I don't have voltage to the brown wire. Fuses in the dash look good however.
    Question: anyone know which fuse the brown wire gets voltage from?
    (I'm guessing a break or bad connection between the fuse to the brown wire?)
  28. tj.
    tj. Active Member
    Canada
    Your manual and wiring diagrams...
    https://www.xjcd.org/service-manuals
  29. Max 700-X
    Max 700-X Member
    AL
    Found the wiring diagram. A bad connection looks to have caused the issue. Brown wire going to thermoswitch now has voltage.
    To test the fan, would I jumper the blue & brown wires? Where is the fan motor ground wire?
  30. xHondaHack
    Orange CT
    Yes. The positive "brown" will be used to jump the blue wire with the key on.
    The ground "black" follows the harness and is through the mounting bolt of the thermostat housing, which is bolted to the frames main downtube (under the fuel tank).
    Here's an old thread on the mod:
    https://www.xjbikes.com/forums/threads/maxim-x-radiator-fan-switch-modification-update.40133/page-2
    Tony
  31. Max 700-X
    Max 700-X Member
    AL
    Thanks xHondaHack, someone before me relocated the ignition cylinder and it appears tried their hand at some "custom wiring" to the fan (which wasn't working).
    I disconnected their wiring and tried to power the fan directly to see if the motor even worked. I got it to run but it's loud. Either the blades are lightly making contact with something or bearing(s). I'll dig into it more this week.
