Maxim 400 Build Project
Discussion in 'Hangout Lounge' started by notnotkarl, Sep 11, 2015.
  1. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    5 minutes is a bit of time for it running on the battery alone. You can bring the ec (choke) to idle rpms and run it for a couple blocks under load to bring it to operating temp faster. Doing this won't hurt it. Just saying.
    Gary H.
  2. notnotkarl
    notnotkarl Member
    VA
    Gary - yeah that'll be the plan but right now the electrics / seat etc are all off so can't ride it! Trying to get it into riding condition before the weather gets too cold here.
    Another question. I really want to remove the stock exhaust and put something maybe a 2-1 or just something that's more brat like. Any good after market alternatives for this bike?
  3. rocs82650
    Middle Tennessee
    K-moe informed me that there are a couple companies that sell complete aftermarket exhaust systems for these bikes (I thought Mac was about the only one). I can't remember if he named them. The Mac system is on eBay.
    Gary H.
    Marving is another: http://marving.co.uk You'll need to look around to fing a U.S. distributor.
  5. notnotkarl
    notnotkarl Member
    VA
    Moved on to clip ons - can't work out if my forks are 33 or 35mm - what size are they on the maxim 400? My tape measure is inches so hard to measure mm (I know I need a new one)
  6. hogfiddles
    Digital calipers will tell you instantly......
  7. k-moe
    Dial calipers will tell you with style though.
    If you have neither, use a length of string to wrap around the fork leg, mark it at the overlap, and then measure between the marks on the string using a ruler.
  8. hogfiddles
    That string will only tell circumference...
  9. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Mathematics will tell you radius and diameter. Anybody for some pi?
  10. hogfiddles
    Yeah, but just measuring the string won't.... You have to use algae bra.
    I'll just use the calipers..... I'm not a mathemagician
  11. MattiThundrrr
    πRsquared? All my pies are round!
  12. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    Circ
  13. notnotkarl
    notnotkarl Member
    VA
    I assumed there was a measurement in a service book I don't own but should!
  14. k-moe
    There probably is, but since so few of the 400s were imported you might have difficulty finding one. Then there is the issue that there are misprints in almost every service manual ever printed.....
    As mentioned, circumfrence/ 3.14 will get you the diameter of the fork legs within the tolernace that you need (they all come in 1.0 mm or 0.5 mm increments regardless of manufacturer).
  15. notnotkarl
    notnotkarl Member
    VA
    It felt great to finally get out on this thing yesterday. Thanks everyone for helping make it happen.
    rocs82650 likes this.
  16. hogfiddles
    Applause!!!!
  17. notnotkarl
    notnotkarl Member
    VA
    I've got lots of work to do this winter - but cables / zip ties are a mans best friend so I make a temporary seatpan setup and hit the open road before the weather got too cold. As long as it stays mild I'll be riding it as is. Then it's a complete strip and build up.
  18. SraWratS
    SraWratS Member
    St. Catharines
    Pictures
  19. Skwerly
    Skwerly Member
    Yucaipa, CA
    Nice thread, will be fun to follow. :)
  20. notnotkarl
    notnotkarl Member
    VA
    SraWratS likes this.
  21. notnotkarl
    notnotkarl Member
    VA
    A problem from a while back hasn't been resolved. The headlight is bright with the key in but as soon as I hit the electric start it goes dim. When I'm riding it flickers bright when I hold in the clutch. I can't ride at night currently. Could this be a grounding issue?
  22. Alan63
    Sounds like it may well be .
    I would not rule out regulator either..
  23. Alan63
    Dirty contacts perhaps as well
  24. notnotkarl
    notnotkarl Member
    VA
    The brake light is fine. So I don't think it's the regulator. I'm going to do some ground testing
  25. Skwerly
    Skwerly Member
    Yucaipa, CA
    Grounds. Always grounds.
  26. notnotkarl
    notnotkarl Member
    VA
    Fixed. Had a bad ground
  27. SraWratS
    SraWratS Member
    St. Catharines
    When I had a bad voltage regulator the lights oscillated bright-dim about the frequency of a cop car light.
    From dealing with boat trailers and bad grounds, I highly recommend coating all electrical contacts with a generous plop of dielectric grease before connecting.
    Always keeps great contacts, the corrosion away and the dielectric properties keep it from shorting out.
  28. notnotkarl
    notnotkarl Member
    VA
    When I got it and how it is currently (not done yet)
  29. XJ550H
    did you just flip the handle bars 180 and down?
    apple sauce and pie Im hungry now:rolleyes:
  30. notnotkarl
    notnotkarl Member
    VA
    Yeah. I did. I'm planning on clip ons but no one here can tell me my fork diameter :) (I just need to go get digital calipers)
  31. XJ550H
    we would only be guessing at that but
    XJ550 Seca fork tubes are 35mm OD,
    it does look like a seca style front end
    my maxim 550 is 35.84 mm which probaly means 35.5 or 36 mm with the +_ tolerances
  32. notnotkarl
    notnotkarl Member
    VA
    Thanks! Going to order some this weekend!!
  33. David Wood
    David Wood New Member
    Raleigh, NC
    Any updates on the bike?! Just found this thread, and man I'm glad I did! I'm about to embark on a similar journey with an '83 Maxim 400 except I plan to do a cafe racer.
  34. hogfiddles
    36 - 550 Maxim
    35 - 550 Seca, xs400 Maxim, possibly xs400rj
    34 -
    33 - xs400 ('77-'81)
