maxim 750 teardown
Discussion in 'XJ Technical Chat' started by Nic, Oct 8, 2017.
  1. Nic
    Nic Member
    Philadelphia
    Anyone know what size bolt on the 82 maxim 750 swing arm
  2. hogfiddles
    Which bolt? Axle pinch bolt? Brake stay bolt? Brake stay-to-brake cover bolt? Swing arm pivot bolt?
  3. Nic
    Nic Member
    Philadelphia
    1507544124627.jpg Pivot
  4. hogfiddles
    Which side do you need? The side shown isn't the 'bolt'
    If you need one, it's the same on almost all the 650-on-up xj's....and I got a bunch of them
  5. Nic
    Nic Member
    Philadelphia
    I'm learning I just wanted to know the size so I can remove the swing arm off the frame
  6. hogfiddles
    Oh, now I understand....
    It's a metric size, but I believe I use my 1" or 1-1/16" socket.....at any rate, I know I use my SAE stuff for that simply cuz it fits. I'm not home right now, I'll check that for you when I get home. IIRC, the solid pivot on the left side is a different size than the locking but on the right side.... I'll check all that for you
  7. chacal
    HCP11336 Aftermarket standard depth 27mm SOCKET, used to remove your swingarm pivot bolt and nut on all XJ650 - XJ1100 models, and the rear axle castle nut on XJ1100 and XS1100 models. Chrome-plated, 6-point, 1/2" drive.
  8. Nic
    Nic Member
    Philadelphia
  9. Nic
    Nic Member
    Philadelphia
  10. hogfiddles
    I just verified... I use my 1-1/16" socket for both sides
  11. Nic
    Nic Member
    Philadelphia
    Thanks I'll play with it tomorrow, hey would you happen to have a pair of stock front turn signals or need anything
  12. Nic
    Nic Member
    Philadelphia
    82 maxim 650
  13. hogfiddles
    Probably--- I'll look.
    Can you send me a pic of your signal mounts? There are a couple different sizes...
  14. Nic
    Nic Member
    Philadelphia
  15. hogfiddles
    Those are the signals, not the mounts--....I need to see the mounts they slide on to.....
