measurements o-ring starter motor xj750f
Discussion in 'XJ Technical Chat' started by xj750y, Dec 1, 2019.
  1. xj750y
    xj750y Member
    Nl
    hi,
    does someone know the dimensions of the o-ring for the starter? (the one that sticks to the block).
    its a bit tricky to measure it without having the actual o-ring (i lost mine during the rebuild).
    thanks
    here is the part number if that helps fits 650 to 900 starters
    O-Ring
    4H7-81847-01-00
  3. xj750y
    xj750y Member
    Nl
    wow.. that's one expensive o-ring.. !
  4. XJ550H
    yes it is do not know what is special about it to cost so much
    may be it is an odd sized oring
  5. Franz
    Is there a list of the sizes of all the engine o rings available? They will be Butyl nitrate l assume?
  6. Polock
    there's no pressure on it. i don't see why rtv form-a-gasket won't work. just try not to let it get inside the motor.
    the ones between the head/cylinders for the yics looked like silicone to me
  7. Franz
    Not sure Polock I was wondering if there were a list of sizes as I can get ones that are suitable.
  8. mlew
    mlew Well-Known Member
    Apex, NC
    Measure it with a set of calipers and see what size it is.
  9. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    On one of my engines the drive chain broke and snapped off the starter motor braking the block where the starter nose fits into. After being welded back together an o ring would not seal. I used form a gasket rtv on the shoulder of the starter. It does make it harder to remove the starter but it works.
  10. Franz
    I just got a micrometer l will try that mlew cheers.
  11. XJ550H
  12. xj750y
    xj750y Member
    Nl
    I ordered the most expensive o ring ever. Dont want an oil leak.
  13. Franz
    Thanks XJ550H good idea I will try that.
