minimum wiring diagram
Discussion in 'XJ Modifications' started by krayzeesmoke, Apr 1, 2012.
  1. FrankenSeca
    FrankenSeca Member
    Gillette, WY
    XJ750 Seca neutral light wiring doesn't interface with the "computer." The (light) brown wire is fused power and sky-blue wire is grounded by the tranny switch when in neutral.
    Edit to add: same color code for XJ650 Maxiim.
  2. LayItDown
    LayItDown Member
    Montgomery, AL
    Hey guys. I did this and have no spark. The only questions I have about it is the wires from the ignitor to the coils. Mine didn't have gray and orange wires coming out of it. It has a blue and white. I tied the white with the grey and the blue with the orange. This is correct right? I haven't found where anyone has made comments about it. Also my ignitor gets rather hot and so does my grey wired coil. Only getting about 3 volts of power on that side. Any ideas?
  3. dustdustin
    dustdustin New Member
    kokomo in
    I am have really bad problems with the wiring on my 1982 Yamaha xj750 maxim and I was want to know if anybody was done there bike like this or is it even doable thx u
  4. 82NewToMe
    82NewToMe Member
    Harrisonburg, VA USA
    Mine was done based on this diagram.
  5. dustdustin
    kokomo in
    Ok I did the wiring just like the dieagram showes and now my bike won't fire I think it has something to do with the tci box and iam stuck what wire should.be hook up Igot the wires going to coils and the pick up on it but there is a black and whit on the plug and a blue on and a black and red doses thoses need to be hooked up to get spark or what and my tci box is good been check help
  6. Garyw
    Garyw New Member
    Grimsby
    Hi this post is from a while back, but did you get the bike running fine after the loom alterations? Ive done a similar job on my Kawasaki GT550 and it works fine.
  7. XJ550H
    82NewToMe was last seen:Apr 22, 2016
    by his posts it looks like he was up and running but his post here does not say he had any trouble with the diagram
  8. saftie
    New York, NY
    I did it based on this diagram and worked for me
  9. dozer
    dozer New Member
    colorado
    Hey buddy, did you start completely over? I have xj700
  10. saftie
    New York, NY
    I ended up wiring from scratch. Easier than hacking the original harness.
    Just did a complete wiring for a different bike because it is also a good opportunity to replace all pins inside the connectors.
