More light at night.
Discussion in 'XJ Technical Chat' started by Door dude, Jul 25, 2017.
  1. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    Guys i have a stock xj 750j. i want to make my front and back blinkers run with light and blink, does anyone know how to do it ?
    do you mean drive down the road with all directional lights flashing ? that is a ticket in any state
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
    I think he means have them on all the time as running lights but still function as blinkers.
  4. XJ550H
    that would be better.
    would be easier to buy lights with the running light and blinker
  5. jayrodoh
    jayrodoh YimYam
    Cleveland
    I've done it on other bikes with a couple of relays, if I get some time I will post up a diagram. All the wires needed are in the headlight.
  6. XJ550H
    front signal lights on a xj700 nc are running lights and turn signals
    he could use those and not have to modify the front wiring system
    and install them in rear. not sure if the atari box would like extra bulbs on the tail light system
    so he would have to add some wiring for that
  7. Door dude
    Correct, running lights and blinkers. Thanks guys.
  8. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Wondered that myself....
    .yes it would be nice to have running lights...
    Better visibility besides just that little taillight....
  9. cgutz
    cgutz Well-Known Member
    SE South Dakota
    FYI
    Some states may have laws against amber tail lights showing when not used as a turn signal.
  10. fiveofakind
    San Diego, CA
    Well, I guess it is time to load up my bike with a bunch of collision avoidance lights then
  11. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
  12. k-moe
  13. cgutz
    SE South Dakota
    Kmoe, can you take photos of what those LED driving lights look like when not masked by the glare?
    I would like to supplement my one headlight on the XJ550.
    Are they highly visible in daylight? The glass lens on my halogen doesn't show up much in daytime unless it is on high beam.
  14. Jetfixer
    My turn signals in the front are a 3 wire dual element bulb , I wired them to the headlight so they are on at all times bike is running . Nice at night and better visibility to the other drivers. ( at least I hope :D)
    Dadoseven likes this.
  15. XJ550H
    are those standard seca lights?
  16. Jetfixer
    No when I bought bike one of the lenses was cracked ... So I ordered 2 aftermarket turn signals they were 3 wire , so so so what to do with the extra wire ... I know lets wire it up !!!!! In how I did it works great and that was 2 years ago !!!!
  17. k-moe
    I can do better than a pic. https://www.amazon.com/dp/B00E0LH8I2/_encoding=UTF8?coliid=I3E5QLEXDIBTSI&colid=3G3X7BCWNX13D
    I wired them on a dedicated circuit using a relay that's triggered by a dedicated switch (that way I can also use them for setup/takedown while camping if needed). Thher are mounted to the turn signal brackets by replacing the special stock bolt (for mounting the rubber part to the steel fork bracket) with a longer bolt.
    The lights are visible in daylight. I can see them reflect from road signs about 2 hours before dusk. At night they light up the road better than the stock high beam (with a fancy new bulb), so should be used as a supplemental high-beam at night, and as running lights during the day.
    Have you cleaned the lens (interior) on your 550?
  18. Door dude
    jayrodoh, i sure would appreciate it if you can find the time to post what you got.
  19. jayrodoh
    jayrodoh YimYam
    Cleveland
    @Door dude Sure no prob, I should be able to get to that tonight. 82 750 max? That way I can make sure I give you the right colors. I was looking through chacals catalog and looks like the electrical connection housings are available so you could even do a plug n play harness. If you google a bit, there are some companies that make a harness you might be able to use for the rear. Little pricey, uses LEDs', and have to cut some wires though.
    I did a little research and running orange lights on the rear is pretty much illegal in any state. I've done it in the past without an issue (always figured more light was better) but just takes one new cop out with his supervisor etc. to get a ticket. You may be able to find some red lenses to fit in there.
  20. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    LED light bar added in place of the stock fog light.
    This one: https://www.amazon.ca/gp/aw/d/B01LB...dpPl=1&dpID=51hO7mteZRL&ref=plSrch&th=1&psc=1
    Mounts directly to the bracket on the lower tree for the stock fog lamp.
    It's crazy bright. I use the headlight for distance, and the led flood lamp for daylight nearby.
    (Yeah, headlight is set too high; need to tear down the front end and move wires to tip it down some more this week)
  21. Dadoseven
    Dadoseven Active Member
    Omaha
    I like it! Looks like it floods the road pretty well.
  22. Wintersdark
    It really, really does - particularly to the sides. I've previously had issues with running lights adding more distant light where the handlebars are pointing but little light nearby, and that's why I got the "Flood" pattern vs. spot lights - you can get these LED bars in Flood or Spot varieties.
    I wanted to have a good view nearby, particularly when I'm doing low speed turns into driveways, parking lots, etc. This certainly does that, with tremendous brightness, and interestingly it doesn't interfere with other drivers nearly as much as you'd think because at a distance it diffuses enough.
    And at $25cdn with free 2 day prime shipping, it was totally worth it.
    Stumplifter likes this.
  23. cgutz
    SE South Dakota
    Clean as a whistle. It is the lens pattern that keeps it from being bright on low beam in daytime. It is adjusted to proper height. Low beam casts arc out, down and to the right. It hits cars ahead a license plate height. High beam is really spectacular!
    Stumplifter and Wintersdark like this.
  24. cgutz
    SE South Dakota
    Kmoe
    Could you show a picture of how these mounted to the turn signal bracket? (I assume it would work on an XJ550 as well?)
    I have had 2 people pull out on me this summer. I need more visibility in the daytime!
  25. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Lights won't make them see you. Only having 4 wheels will...:(
  26. XJ550H
    his turn signals do not have the long rubber stem that a 550 has but it mounts to the frame in the same way. it looks and sounds like he replaced the clamping bolt in the signal body with a longer one and removed the short bolt in the led light
    bolt #17 in this link
    http://www.partzilla.com/parts/sear...81/XJ550H/FLASHER+LIGHT+XJ550H+J+K/parts.html
  27. k-moe
    Bingo!
    I removed and replaced the special (square body) bolt that mounts the rubber portion of the signal to the mounting bracket on the fork.
    I wired them to a dedicated circuit using a 12v relay and a illuminated rocker switch to trigger the relay. The switch is mounted to the mirror stalk, just above the high beam switch.
