More parts available again
Discussion in 'For Sale, Trade/Swap, Wanted' started by hogfiddles, Oct 30, 2016.
  1. hogfiddles
    Time to clear some more parts out--- here's a few that I have:
    Xj550 Maxim head - 1
    Xj750rj tail cowl (bare) - 1
    1982 xj650rj tail cowl (silver,but not clear-coated) - 1
    Xj650 Maxim tail light assemblies - 4 of them. ( I have a 5th available, but one of the ground wires broke off of the socket.....if you're good at soldering----)
    xj650 Maxim grab rail - 2
    Let's' talk........and if there's other parts you need, ask me. Parts are primarily xj650 Maxim, xj750 Maxim, xj750 Seca, some xj550 Maxim, and a little bit of 700/700X, and a few other bits.....I have run out of room------lol
    Dave F
  2. Toomanybikes
    Tsawwassen bc
    So if I have a 650 Maxim frame with title for you then you could make a bike from spare bits in no time:)
  3. hogfiddles
    Some more--
    550 Maxim exhaust--Complete or will part out.......
    Pipes are decent, not perfect though; collector is very good, a small ding on one side shield; mufflers are nice, a small ding on the left muffler, but nice and shiny
    Generic fender that was on an xjj650 maxim - very good condition
    Let me know what else you might need---
    Dave Fox
  4. hogfiddles
    Well....I already have several frames that I'm collecting parts onto, too......they'll be done sometime, but I STILL have a lot of other parts to move out
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    So parts actually LEAVE your barn? That's not how a hoard is supposed to work!
    Toomanybikes likes this.
  6. joejr2
    Santa Fe,NM
    By any chance, Would that 550 exhaust fit an "82" xj650 seca with a stock engine, frame and footpeg brackets.
    And, Do you know whether an xj 750 maxim tank can be mounted on an "82" xj650 seca frame and be compatable
    with the stock seca seat ?
  7. hogfiddles
    Exhaust won't fit.
    Will try to swap tanks around this weekend to find out
  8. hogfiddles
    Ok, here's some updated tank swap info---- I'll start trying to pull everything together into a new forum devoted just to this topic. Anyway, Joe, you asked about the Maxim tank, but then private mailed about the 750r tank instead--so.....here's how a 750r tank looks on the 650rj.
    It looks surprisingly decent.......if the color were to match, it would look almost like it was intended. This is just a test for fitment, though.
    It is a good fit, as I reported earlier, but here it is with the 650rj seat installed, too. The ONLY issues:
    1. The side cover mounting hole bushings must be good and in place to keep the side cover down far enough
    2. The 650rj rear tank mount rubber must be used to keep te 750rj tank high enough so it does not ride on the side cover mounting tabs
    3. The rear tank mount hole is juuuust a hair back from the center post, so you have to really work the rubber into the hole before putting the top mount pieces and the bolt in. A little warming with a heat gun, and some vasoline help the rubber to slide in. Some CAREFUL light prying forward will help to get the rubber in, as it is a snug fit.
    4. The Sidecovers mount holes that are in the rear corners of the tank ARE visible. BUT some 'creative' decoration or camouflage. Will make them very unobtrusive.
    Here's two pics of a 750rj tank on an '82 xj650rj non-turbo, with the original seat INSTALLED...not just sitting there. (In process of redoing the cover)
    I did not have time to drop the Maxim tank on...... Will do that later
    Dave
    ecologito likes this.
  9. hogfiddles
    Xj750 Maxim tank on an xj650rj...... It physically fits, but the gap between the tank and the seat is awful
  10. MattiThundrrr
    Oh Great and Mighty Hoggfiddles, xj wizard, host of central NY carb clinic, owner of tank swap guinea pigs! Will 650r tank fit on 750 r? Will Maxim tank fit on 700/750x? 400 on a 900? Will a lawnmower tank fit a chainsaw? When you set up THE ULTIMATE TANK SWAP THREAD, all will await your answers!!!
    James height likes this.
  11. hogfiddles
    650r on 750r - if you swap the 650r triple tree onto the 750r, the tank will fit. BUT in doing so,I think you will be putting a weaker suspension on, and other fender/wheel/brake issues will be present, too
    Maxim tank on 700/X - which years? The 85/86 maxim tank IS the tank
    400 on 900 - totally different
    Lawnmower tank on chainsaw - yes
  12. MattiThundrrr
    You caught me. Only one of my questions was serious, the rest were an attempt at comedy through hyperbole, but now I am eyeballing the chainsaw!
    hogfiddles likes this.
  13. hogfiddles
    I know..... But half of the fun is answering a funny question with a funny but serious answer. ;)
    quebecois59 likes this.
  14. Nic
    Nic Member
    Philadelphia
    Would you happen to have a front brake caliper for xj650j I also need a rectifier/ regulator
  15. hogfiddles
    I'll check for both
  16. hogfiddles
    Is that 750 Seca seat on your 650 maxim really comfortable? It doesn't look it to me-----/
  17. Boyd1703
    Boyd1703 New Member
    Orange nsw
    Hey mate would you have the carby off the xj550 by any chance?
  18. hogfiddles
    I don't have a 550 carbs ready to go at the moment
  19. USAF01
    USAF01 New Member
    Perry, Ga
    Do you still have any 650 parts?
  20. hogfiddles
    I have lots of parts.... the bigger question is "what do you need", so start a private conversation with me
    Dave
  21. Carson
    Carson Member
    colorado
    Will your 550 exhaust fit an xj700?
  22. XJ550H
    no a 550 exhaust will not fit an xj 700
  23. hogfiddles
    Nope
  24. Toomanybikes
    Tsawwassen bc
    With enough cutting and welding anything will fit anything.
  25. hogfiddles
    Ad. The time you're done cutting and welding it won't fit......lol
  26. k-moe
    Welding...Pffft. BFH and bailing wire :)
    Stumplifter and Toomanybikes like this.
  27. Toomanybikes
    Tsawwassen bc
    Naaaa JB weld and duct tape
  28. XJ550H
    just leave it off great light show at night
    chacal likes this.
  29. quebecois59
    A Redgreen-type fix...
  30. True
    True New Member
    New Zealand
  31. True
    True New Member
    New Zealand
    Hi do you still have the 650 tail lights? And do you happen to have maxim badges and or 650 badges? Thanks
  32. hogfiddles
    Gone.... sorry
  33. Toomanybikes
    Tsawwassen bc
    Welcome To the club True.
    I have a couple of xj650 maxims for parts. Will post a pic or 2 of what I have when it gets light .
