Motor oil, is it lubricated by the oil in the gearbox or is there another inlet for a different oil?
Discussion in 'XJ Technical Chat' started by Dylan Mattson, Sep 8, 2023.
Tags:
  1. Dylan Mattson
    Dylan Mattson New Member
    Moscow Idaho
    I recently acquired a 1981 xj650 maxim and don't really know much about it, want to make sure everything has clean new oil, fuel, and anything else it might need, curious if all oil is through the gear box or if there's an inlet for oil specifically for the motor?
  2. Dan Gardner
    Minneapolis, MN
    Gearbox and crankcase share oil.
    Dylan Mattson likes this.
  3. Dylan Mattson
    Moscow Idaho
    Thank you
  4. Dan Gardner
    Minneapolis, MN
  5. short_circutz
    short_circutz Active Member
    Sault Ste Maire, On, Canada
    Avoid synthetic, as it can cause premature failure of the starter clutch.
  6. k-moe
    That used to be the case, but isn't anymore. There are several very good synthetic oils that are formulated to be used in older motorcycles, and they will not cause starter clutch slippage.
