motor
Discussion in 'XJ Technical Chat' started by Jburton, Dec 27, 2017.
  1. Jburton
    Jburton New Member
    Wisconsin
    recently got a new bike and before driving it i went to change the oil and found what looks to be clutch material in the oil. does anyone know what this might be? would I be better off finding a new motor? does any other newer model engine bolt up to my 81 750 seca??? any help is appreciated
  2. Jetfixer
    First welcome aboard. Since you say you recently bought the bike you probably know little that previous owner had done to the bike. If the clutch is shot it can be replaced but why would you want to replace the engine? How many miles are on the bike? Is the clutch slipping? We need more info on what is happening to advise you on what to look at. Chuncks in the oil is never good but it could also be signs P.O. neglected changing the oil was oil really black ? You might have to flush oil another time to clean it out seafoam helps . Just my 2 cents good luck.
    Stumplifter likes this.
  3. Chitwood
    Chitwood Well-Known Member
    Fort Atkinson, Wisconsin
    If it's hard plastic looking chunks, it's possible that the chain guide is disintegrating
    Simmy and Stumplifter like this.
  4. XJ550H
    pull the clutch cover see what it looks like. if bike has oil in it you mak have to drain it or lean the bike over and support with out kick stand.
    then pull the shifter side cover and see if there are chunks in the hole, see this post
    http://www.xjcd.org/emergency_guidectomy
    Jburton and Jetfixer like this.
  5. k-moe
    Would you mind keping all of your questions about this motorcycle in one thread please.
