My 82 XJ750 Project
Discussion in 'XJ Modifications' started by chopper716, Nov 27, 2008.
  1. roloncali
    roloncali New Member
    Now I got it...I will ask again once I started doing the front side of my bike
    Right now I'm working on the back end..I will download some pic of my project bike..then give me some suggestion..
  2. roloncali
    Chopper, I'd noticed you changed you air cleaner..(look individual filter on every outlet...and it looks way nicer...where did you got it from? & what things need to be done to accomplish these ?thanks
  3. chopper716
    chopper716 Member
    Victorville, CA
    I got them off of ebay, just search for pod filters. All you gotta do is take of the airbox and put them on. Some say you have to re-jet when you do this but I've seen others say they had no problems without re-jetting.
  4. QuarterHorse
    QuarterHorse Member
    Des Moines, Iowa
    I'm diggin' it man. I'll be re-fabbing some things on mine after looking at this build. Although I'm so close I'm going to finish it up and ride this summer the way mine is heading. Keep it up!
  5. crath
    crath Member
    Peoria, IL
    Number one is one the left side of the bike. ...left side when you are sitting on the bike facing forward. ....left side is the side with the shifter lever.
  6. chopper716
    chopper716 Member
    Victorville, CA
    Cool thanks, i think that's the way I have them.
  7. roloncali
    Hey Bro, I ordered my 4air pods..but dont know the size of the 5th one, (red one in your bike) I think 650 & 750 got d'same size...
    " Frustrated because...I'm taking out the air filter box out of my bike,,but cant take it off "i guess need to take off the carbs..
  8. chopper716
    chopper716 Member
    Victorville, CA
    :lol: :lol: Sorry to laugh but I had the same issue. I used my dremmel and cut that sucker out of there.
    As for the small breather filter you can get one of those at Autozone or Pep Boys or your local autoparts store.
  9. chopper716
    chopper716 Member
    Victorville, CA
    Anybody know if the ignition coils have to be grounded. The way I have them mounted there isn't really a solid connection against the frame.
  10. chopper716
    chopper716 Member
    Victorville, CA
    Looks like I have a bad set of ignition coils
    They worked before I started, but I got the circuit tester out and I'm getting power to the coils but no spark coming out of them. Can that happen when they're just sitting around?
  11. chopper716
    chopper716 Member
    Victorville, CA
    I have a hard time beleiving they just went bad both at the same time. Anyone have any ideas?
  12. Amoney
    Amoney New Member
    Oswego, Illinois
    Did you disconnect all of the electrical components on your bike before you did any welding?
  13. chopper716
    chopper716 Member
    Victorville, CA
    Yeah.
  14. chopper716
    chopper716 Member
    Victorville, CA
    Well I'm stuck. I've been trying to wire this thing and get it to start up for a couple weeks now and no dice. At one point it was turning over but not getting spark; now it's not even turning over. I've replaced my TCI box and my starter relay and still not working. I completely disconnected everything last night and tonight will start over again.
    I'm getting a little discouraged to say the least.
  15. Thee_oddball
    Thee_oddball Member
    this really sounds like a ground issue , did you check the kick stand saftey, neutral switch,kill switch? is there full power to the dash just nothing happens when you hit the start button?
    and here is a BIG electrical schematic from my service manual
    http://jg6.net/images/elec1100-big.jpg
    S!
    p.s this is from and xj1100 manual
  16. chopper716
    chopper716 Member
    Victorville, CA
    well I'm not using any of those because I'm going bare bones with just a headlight and tail/brake light for now.
  17. chopper716
    chopper716 Member
    Victorville, CA
  18. Plumber
    Plumber Member
    Wales
  19. chacal
    Cool! What was it?
    By the way, that tag will obviously get you a $1200 fine in Florida..........
  20. dwcopple
    dwcopple Active Member
    bay city, michigan
    now you're talking!
  21. Plumber
    Plumber Member
    Wales
    sounds great
  22. chopper716
    chopper716 Member
    Victorville, CA
  23. Plumber
    Plumber Member
    Wales
    looking fantastic
  24. TheHound
    TheHound Active Member
    Scotia, NY
    Sounds nice!
    Did you go with the single rotor for the look?
  25. chopper716
    chopper716 Member
    Victorville, CA
    Yeah pretty much, I may put the other one back, not sure yet.
  26. chopper716
    chopper716 Member
    Victorville, CA
    Been a long time but here's the bike as it is right now. Need to repaint the rear fender.
  27. schooter
    lookin really nice
  28. KennyNapalm
    KennyNapalm Member
    Calgary AB
    dammit - i hate you and your bike - cause its so sweet. ...
    hhahah good job
  29. xulf13
    xulf13 Member
    Franklinton, NC USA
    Wow chopper, where you been? I like how your bike turned out. Man you change paint colors as if it was underwear, LOL.
    Hey how is your bike running with the pods and straight pipes? What was your final jet sizes that you used?
  30. chopper716
    chopper716 Member
    Victorville, CA
    Stock jetting man, it runs fine for me. I do go through paint colors a lot, LOL. But this is an entirely new gas tank so I didn't paint it. I just need to re-paint the rear fender to match.
    Thanks guys for the positive feedback.
  31. 1FASTHOE
    1FASTHOE Member
    GILBERT AZ.
    lookin good chopper, do you have any pics of your exhaust ? looks like two y's and straight pipes ? and your kick stand is cute too...lol
  32. NORMFERG
    NORMFERG Member
    Morgans Point Texas
    any issues with overheating since you painted the engine?
  33. chopper716
    chopper716 Member
    Victorville, CA
    Nope, put about 300 miles on it in pretty warm weather and no problems.
  34. justifidejoe
    justifidejoe Member
    West Lafayette, IN
    Nice bike chopper. What headlight do you have installed? I didn't see it mentioned in previous posts. Do you have it running straight to battery?
  35. chopper716
    chopper716 Member
    Victorville, CA
    It's just a scalloped headlight I found on eBay. Yeah it runs on a switch straight to battery
  36. koolaid5
    koolaid5 Member
    Chambersburg, PA
    I like the bars you eneded up going with in the end there. Where did you pick those up at? The seat too? Really nice clean looking bike. Oh, and what did you use to paint everything? motor, bodywork....?
  37. chopper716
    chopper716 Member
    Victorville, CA
    The bars were made by slimsfab, most of the paint is rattlecan duplicolor. Engine and pipes are just high temp paint from autozone
  38. xharleyx
    xharleyx Member
    Pikeville, KY
    well my xj seems to be traveling down almost the same road as yours and I'm having the same exact issue you did with your coils. Worked fine one day, then nothing. What was the issue if you don't mind sharing?
    i've metered and tested every wire on the bike and everything checks out, I don't get it
  39. chopper716
    chopper716 Member
    Victorville, CA
    Kind ended up replacing the box and that seemed to have worked
  40. xharleyx
    xharleyx Member
    Pikeville, KY
    TCI box?
  41. chopper716
    chopper716 Member
    Victorville, CA
    Yep, I pulled mine apart and it was fried
  42. xharleyx
    xharleyx Member
    Pikeville, KY
    looks like I will be doing the same. thanks bro
    love the bike, your was the inspiration behind mine, hopefully i'll get some pics up soon
  43. mattyj1907
    mattyj1907 New Member
    Love the bike, what size tires are you runnin?
  44. koolaid5
    koolaid5 Member
    Chambersburg, PA
    How much did the bars cost? If they can do them for fairly cheap maybe I can get a set made as well.
