Mystery wire 1983 Maxim 750
Discussion in 'XJ Technical Chat' started by Machine1964, Aug 21, 2017.
  1. Machine1964
    Machine1964 New Member
    Des Moines Iowa
    20170821_205934_Burst01.jpg 20170821_205852.jpg 20170821_205858_Burst01.jpg 20170821_205934_Burst01.jpg 20170821_205852.jpg 20170821_205858_Burst01.jpg 20170821_205934_Burst01.jpg 20170821_205852.jpg 20170821_205858_Burst01.jpg [​IMG] [​IMG] [​IMG]
    I bought this bike cheap and rode it home . It ran and started fine. It was in dire need of some tlc. I started tearing it down to replace and refurbish parts . The stock fuse box only had one glass fuse in it,the rest of the wires had been stripped and wire nutted together. I replaced the stock fuse box with one that uses modern blade fuses.When I went to test it the starter button will no longer work and the bike won't start even jumping across the solenoid.
    During the tear down I found this wire that was white with a red stripe.It had been stripped down about 1/4" but was hooked to nothing.I believe I've traced it to the keyswitch but cannot locate where it goes.I'm thinking this is the problem and all I have to do is figure out where to hook this wire up , but cannot find a accurate wiring diagram for a 1983 Maxim 750 that shows a white wire with a red stripe.Does anybody know offhand where this wire goes.I want to get the bike starting and running again so I can get back to fixing it up.
    Unfortunately it has nothing to do with your no-start problem.
    That is for the battery monitor. Without it hooked up the bike will run, but you'll get a warning light.
    It goes like this.
    Putting a resistor in allows you to use a maintenance free battery and retain the low battery acid warning light, but turn it into a low battery voltage light.
    Based on your diagnosis, you need to pull the starter and replace the brushes (clean and re-grease the planetary gears too). Start a converstion with Chacal; he has the correct rebuild kit in stock.
  3. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Machine,
    See attached ....wiring diagram from '82 Maxim XJ750J
    Excellent reference for your existing project.....
    You have a lot of work ahead of you......Good luck.....we are here to help....
    Pods...another roadblock in my eyes......they are a lot of trouble to dialed in properly....
  4. XJ550H
    completly wrong fuses in your box
    start by checking the work you did.
    are you getting voltage on the qd input side of fuses?
    when you turn on keydoes your headlight come on?
    horn work blinkers blink?
    bike will not turn over even if you bridge the solinoid nuts look at that positive battery cable and crimp looks suspect to me
    do you have 12 volts at the nut and starter when you push the starter button?
  5. fiveofakind
    San Diego, CA
    Your bike looks like an 1982 ...are you sure it is an 1983.....??
    Do you have buckhorn style handlebars.....??
  6. XJ550H
    your right the 82 had atari package and buckhorns. rectangle headlight and aux light
    rectangle blinkers.
    83 has crome handle bars and round lights no atari
    needs to check his vin number on frame and motor
    check your motor vin and frame vin at this link
    http://www.dissingermoto.com/
  7. XJ550H
    our starter button may not be grounded if it is not hooked to handle bars I will check mine in the morning.
    check your inbox
  8. fiveofakind
    San Diego, CA
    If his Vin is 15R...then it is an 1982...
    TheCrazyGnat likes this.
  9. Machine1964
    Des Moines Iowa
    Wow,lots of good info .Thanks everybody.I'll keep you updated on what I find out.I'm not a newbie,but this had me scratching my head.Always loved Yamahas and bought this bike as a back up and daily rider to my other bike which I built.Here's a pic. FB_IMG_1495590301964.jpg
    Stumplifter and TheCrazyGnat like this.
  10. Machine1964
    Des Moines Iowa
    It is an 82 (I just got the title) . It turns over fine when you jump across the solenoid, just no spark. Lights and everything come on with the key, but when you hit the starter button everything dims like it supposed to but the starter doesn't spin. Thanks for the info on the wire. The guy I bought it from said he couldn't figure out the warning light. I'll add the resistor this week.
  11. XJ550H
    clean the right control inside; the light is not diming it is shut off when you press the starter button because the starter button is the headlight contact when released. no headlight relay.
    then test the solinoid of course it could be the safety systems shutting down the starter relay
    start by pulling the sidestand safety relay near tci has blue marking
    Machine1964 likes this.
  12. XJ550H
    when you turn on key you should hear relay click closed both sidestand and starter relay when bike is in neutral
  13. Machine1964
    Des Moines Iowa
    What do I check first if I don't?
    Also which one is the starter relay?
  14. Machine1964
    Des Moines Iowa
    How do you bypass the safety relays to test to see if that's the problem?
  15. XJ550H
    to bypass sidestand relay you just remove it
    if you want to bypass the starter safety switch you unplug the relay and put a jumper from red/white wire to red/yellow (may also be red/white)wire. this will put power to solinoid and should turn bike over when you press starter button.
    also unplug the black white wire at the tci unit should be a rubberboot about 3 inches from tci this is the wire that the sidestand safety relay grounds out to to prevent starting (should not be affected when ssrelay is removed
    look at the clutch safety switch in clutch perch see if it is coming apart if it has failed you can go into headlight bucket and unplug it this will cause the bike to only start in neutral. you can put a jumper lead across the connector in headlight bucket( it is green) this will allow bike to start in gear with out pulling in the clutch lever
    1982-84 XJ750 Maxim and Midnight Maxim models:
    Flasher: near the steering headpipe, on right side frame rail, under the right side ignition coil.
    Flasher canceller: under the rear of gas tank.
    Starter motor solenoid/relay: attached to and behind the battery box.
    Starter/Ignition cut-off relay (no color): behind self-canceller, under rear of tank.
    Sidestand (kickstand) relay (blue): behind the left frame side cover, on the plastic regulator-rectifier mounting plate.
    Headlight relay (yellow): not used.
    1982 XJ750 Maxim safety relay single diode: outside the main wiring harness bundle, in the area just behind the fuel tank.
    1983-4 XJ750 Maxim Diode block: inside the headlight housing.
    Neutral switch: in a hole in the bottom of the crankcase, just "outside" of the oil pan, on the bottom of the engine, up inside a recessed "well".
  16. XJ550H
    if you look on page 28 (24 on paper) of the fsm for xj750J you will see wiring diagram for starting system. note the starter button apears in 2 locations because it controls headlight
    starter relay is solinoid
  17. hogfiddles
    That's an '82....see the Atari dash? The '83 had the same gauges as the 650 Maxim
  18. Polock
    back in the day, the easy solution for that wire was to put it to the + of the battery and forget it
