need 83 kz 1100 ltd tachometer
Discussion in 'Other Motorcycles' started by joejr2, Apr 13, 2017.
  1. joejr2
    Santa Fe,NM
    I have a 1983 kawasaki kz1100 ltd shaft with a bad tach module. If anyone has one or an instrument
    cluster, Broken speedo side or cracked lens ok I only need a tachometer module to put into an existing
    instument cluster housing.
  2. XJOE550
    XJOE550 Active Member
    Inverness, FL
    Go to www.kzrider.com/forum. They have a "Wanted" section that you can post in. Better yet, PM member kz100006. Should be able to set you up with a nice used set. Or anything else used for that matter. At a good price.
