Need a part not in the diagrams!
Discussion in 'XJ Technical Chat' started by GTB, May 19, 2026.
  1. GTB
    GTB New Member
    England
    I’ve searched various xj900 31a parts sources and diagrams and I find the part I need isn’t even in the official Yamaha diagrams with no luck.
    I need the valve cover retaining support that sits over the cam shaft, or the one with the the cam bearing surface. Although that’s on the diagram but not identified.
    Any suggestions other than JB weld….
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  3. Dave in Ireland
    Ireland
    You mean the cam cap that's threaded for the valve cover?
    Every head and its matching cam caps are line-bored, so they're not sold seperately.
    It's been done, but time-taking and very fernickety, to use another cam cap and make it fit yours.
    Best of luck with that.
    cds1984 likes this.
  4. GTB
    GTB New Member
    England
    Thanks for the responses,
    The one I need doesn’t have a bearing surface, it straddles the camshaft.
    The one shown in the diagram is a line bored one but still has no part number.
    I’ve sourced a set off another bike, even though I only need one.
    fYI. I’ve since found outit’s available as aftermarket from info.xjforever.com
    HPC 22924 non-bearing cam cap. The sj900 uses 4.
  5. Dave in Ireland
    Ireland
    Oh, it's one of those inner ones.
    Right, gotcha.
