Need a wiring Guru for 1981 XJ750 Seca project
Discussion in 'XJ Technical Chat' started by skiprrdog, Feb 18, 2016.
  1. skiprrdog
    skiprrdog Active Member
    Tucson, AZ
    Yes, I did. Did throttle shaft seals, washers. Polished the slide bores with 2000 grit paper and WD40, and hand polished (no sandpaper) the slides themselves, pass the clunk test with flying colors.
  2. skiprrdog
    Tucson, AZ
    It just looks that way, I had the fuel supply hanging from a rafter about four feet above the carbs, but the hose was so long it dipped a little bit in the picture.
    rocs82650 likes this.
  3. k-moe
    Well they definitely won't be leaking on the bike then.
