Need Help Removing Crankshaft for Head Removal
Discussion in 'XJ Technical Chat' started by Preston Packham, Jul 6, 2019.
  1. Preston Packham
    Preston Packham New Member
    Tooele, Utah
    I'm trying to find how to remove the entire head for gasket replacement on my xj550. Anyone know how?
    ,is it maxim or seca 550
    why do you think you need a head gasket?
    the disassembly starts at the top I assume you do not have a fsm manual you do not need to remove crankshaft.
    do you just want to replace head gasket?
    do you have the carbs off? exhaust off
  3. hogfiddles
    You don't need to remove the crank to remove the head. Just break the cam chain
    Or leave the chain intact and remove the cams before removing the head.
    More work, but less money. (can you tell that I'm pinching pennies more than usual? ;))
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    The cam chain dose not need to broke. Remove the sprockets on the cams then pull the cam out after removing the cam caps . Be sure to keep the cam caps in order thay must be put back in the same position.
  6. lostboy
    I got to type faster. Good work @k-moe
    KrS14 likes this.
  7. k-moe
    What you need is a time machine.
    Let me know when the brown truck delivers it, because I need one too.
  8. hogfiddles
    Ya'll are right-- I was falling asleep and thinking about the crank.....duh. Going back to sleep. Pay no attention to the man behind the curtain.....
  9. k-moe
    Breaking the chain is easier though.
    Forgive me father, for I have buorboned (and beered (annd am currently enjoying a mighty fine pie))
  10. Franz
    On the subject of pennies Billy Connolly said copper wire was invented by two Scotsmen fighting over a penny.
    k-moe and XJ550H like this.
