Need help XJ 400 Special
Discussion in 'XJ Technical Chat' started by Igor, Oct 23, 2009.
  1. Igor
    Igor Member
    Santiago CHILE
    Why do you say that is 1981, in all the papers that I have it´s a 1983, anyway dont matter to me, I ask just to have the right information
  2. ktcubed
    ktcubed Member
    St. Augustine, FL
    This is from Chacal's VIN id page. (see below). It seems that your numbers fit in the bold and highlighted region. Did you look on the frame head tube (where the handle bars bolt on) on the right side for a long vin. The one you gave is the short vin from the engine. Could be a replacement engine.
  3. Igor
    Igor Member
    Santiago CHILE
    Crystal clear, now where do I get parts for it, not that I need many just a
    few
  4. ktcubed
    ktcubed Member
    St. Augustine, FL
    Send a PM to Chacal. He'll be able to get you anything you need.
  5. Igor
    Igor Member
    Santiago CHILE
    I allready did, but I did not get a possitive answer, maybe with the new information of the model, he could do something else
  6. Igor
    Igor Member
    Santiago CHILE
    Hello, anybody nows the compression rates of the XJ 400 the 4 cylinder
    the four cilynders?????????I mean the compression of each cilynder.
  7. AndrewM
    AndrewM Member
    Cebu, Philippines
    Igor
    Here are the valve specs (engine cold):
    Inlet - 0.11 - 0.15 mm
    Exhaust - 0.16 - 0.20 mm
    With regard to compression figures, do a search on the site. The actual reading whilst important is not the only issue. The reading across the four cylinders is just as informative as the individual cylinder readings. As I say do a search for "XJ550 compression" and you are sure to come up with something!
  8. Igor
    Igor Member
    Santiago CHILE
    Sorry, but if I ask ,its because I haven´t found the information and not cause I haven´t look for it.
    Thanks for the valvs info.
  9. AndrewM
    AndrewM Member
    Cebu, Philippines
    Just did a search and came up with this from another post:
    compression test at sea level with the motor cold should come in at 121psi standard and a minimum of 100psi with a maximum difference of 14psi between cylinders
    Good luck.
  10. ktcubed
    ktcubed Member
    St. Augustine, FL
    Sorry, I talked to him and it seems he does not have much for your model. Only the things it has in common with the American bikes.
    Perhaps there is a Yamaha dealer in your area you could check with. Sometimes parts are hanging out in the dusty recess of the store room.
  11. ktcubed
    ktcubed Member
    St. Augustine, FL
    numbers for the 550 are 121normal 100 minimum and not more than 14 psi difference between cylinders.
  12. Igor
    Igor Member
    Santiago CHILE
    Found the comprssion rates. it´s 121psi with a difference of 14 psi between cilynders :lol:
  13. Igor
    Igor Member
    Santiago CHILE
    The Yamaha dealer here, did not import that particular model, so they dont keep or import any parts,
    my only chance is this forum for what ever i may need ,anyway I coming
    along pretty well with my proyect.
  14. Igor
    Igor Member
    Santiago CHILE
    What do you think, after the compression test I have , two cilynders with
    96 psi and two with 105, are those numbers aceptable???
  15. SQLGuy
    SQLGuy Well-Known Member
    What your altitude there? Compression numbers will be lower at high altitude, though those sound a bit low regardless.
  16. Igor
    Igor Member
    Santiago CHILE
    I´ll say around 1800 feet over sea level.It´s in Santiago of Chile.
  17. SQLGuy
    That's not that high of an elevation.
    At 2000 feet, you'd be losing about 7%. I'd say that, at 96psi, you're just over the minimum, which would be about 93psi at your altitude. I hope that you measured it cold. If it was hot, then the numbers are definitely low.
    However, if your valve clearance is too tight, your valves may be hanging open, which would significantly reduce compression test readings. Have you checked the valve clearance yet?
  18. Igor
    Igor Member
    Santiago CHILE
    Well , the measured was made with a cold engine and two of the intake valvs are with the clearence I´ll said to tight, I mean Less than the recomended, one is less than 0.08 and the other one is´t almost 0.0
  19. ktcubed
    ktcubed Member
    St. Augustine, FL
    Well, until you adjust those clearances the readings won't be worth any thing.
  20. Igor
    Igor Member
    Santiago CHILE
    I realise that, but the good thing is that, it´s not gone be any lower than the firts reading and that ain´t bad
