Need Hitachi HSC 32 starter jets
Discussion in 'XJ Technical Chat' started by Richard Elbon, Dec 18, 2018.
  1. Richard Elbon
    Richard Elbon Active Member
    LaCenter Washington
    Need all four as they were clogged and had to ez out them to get em out. Anyone know where I can get just those? Kits didn’t have any.
    start a conversation with member chacal he is a supporting vendor and has the parts or go to his web site www.xj4ever.com and send him an email he will send you a quote.
  3. Richard Elbon
    LaCenter Washington
    Did just now,thanks.
  4. Polock
    i don't think you were supposed to take those out, you might need float bowls now
    Jetfixer and Colin 85 700 like this.
  5. Richard Elbon
    LaCenter Washington
    They appeared to be pressed in and made of brass and are a restricted with a .040 designation. Listed separately in the service manual.
  6. Toomanybikes
    Tsawwassen bc
    Should have asked about those. They will clean out with cleaner and a little heat.
    Colin 85 700 likes this.
  7. Richard Elbon
    LaCenter Washington
    I left carb cleaner in the passages overnight and blew them out today,nice and clean now.
  8. Toomanybikes
    Tsawwassen bc
    So did you remove them? They have to be there ! If not as @Polock stated you will need new bowls.
  9. Richard Elbon
    LaCenter Washington
    Yes I removed one.The other three are clean. The one was clogged with what looked like hardened concrete. So now I need that jet which is press fit or a new bowl with a clean jet in it.
  10. Toomanybikes
    Tsawwassen bc
    Never seen those jets for sale, so new bowl required. Pm me if you can’t find one.
  11. Richard Elbon
    LaCenter Washington
    Reason I thought they were replaceable is because they are listed separately on Babbitts catalog. I don’t have the tools to clean that small a jet. So I have some coming now that have been sonically cleaned. Should be all ok after that.
  12. Toomanybikes
    Tsawwassen bc
    You do mean this one that’s NOT available. As far as I know they have not been available for many years.
  13. XJ550H
    I think 1980 and earlier they could be changed out
    hogfiddles You screwed then up. The only ones that were removable where in the 1980 '80 650 bowls, I don't recall the 750 bowl having a removable jet…
  14. Polock
    seal it off, it'll start on 3 cylinders and you only need it for a minute or two. then find one at your leisure, no problem
  15. Richard Elbon
    LaCenter Washington
    I’ve got it handled thanks
  16. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    What made you want to easy them out......???
    A small drill bit from Chacal would have cleaned them out by hand turning the bit into those passages from both ends......
    Never heard of anyone trying to take them out......that is a first.....
  17. Richard Elbon
    LaCenter Washington
    They were pressed in and listed as a separate part on the bike bandit and others parts list.
