New bolts on a 1982 XJ750 -Life hack
Discussion in 'XJ Technical Chat' started by Adam Shaffer, Jun 26, 2017.
  1. Adam Shaffer
    Adam Shaffer Member
    Alden,Michigan
    Just wanted to pass the word on "Life hack" that I found by accident. The bolts to the air box, Side covers, and sure other parts are exactly the same thread pattern ( and a few same length) from the sealed bolt packs that come with a flat screen TV mount bracket. work great and look good.
  2. Polock
    that's great but what holds your TV up ?
    Stumplifter likes this.
  3. hogfiddles
    The handlebars
    Being the same thread pattern doesn't mean that they are suitable. Stick to using them in non-critical areas.
    Lightcs1776 and hogfiddles like this.
  5. Polock
    if the handlebars hold the TV and all the channels have sky and treetops on you should slow down :)
  6. Adam Shaffer
    Adam Shaffer Member
    Alden,Michigan
    the bolts that were for the tv the bracket is holding. ;)
  7. Adam Shaffer
    Adam Shaffer Member
    Alden,Michigan
    I have not tried them anywhere else other then the air box cover ( 3 bolts) and the two side covers ( the battery box cover , and matching cover on other side). I am not sure where else the screws are the same. It was more of a FYI because I almost got ride of the bolts since it did not work for anything around my work shop. Now I will keep them knowing they work on my bike.
  8. Polock
    those bolts are metric 6mm by 1 pitch by length or 6x1x length. most any bolt on the bike that takes a 10mm wrench or a "philips" is that size. just incase you
    need to buy some one day
    Adam Shaffer and TheCrazyGnat like this.
