New here and owner of xj 650 y.85
Discussion in 'Hangout Lounge' started by Andy555, Mar 28, 2017.
  1. chacal
    The boots have shrunk over time........
  2. hogfiddles
    Looks like it
  3. Andy555
    Andy555 Active Member
    Slovenia
    Soo need new ones,a?
  4. Andy555
    Slovenia
    Chacal how is with sending items to slovenia from you?
  5. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    air box is forward all the way?
  6. chacal
    Slovenia is just a mouse-click away for us via the Postal Service!
    The shipping fees may be rather steep though, if there are other parts that you need, best to order them all at one time.
    Send me an e-mail at info@xj4ever.com or use the "Start A Conversation" feature on this website so we can discuss further.
  7. Andy555
    Slovenia
    Aha ,ok i will check for what all i need then we talk abouth it,tnx for now
  8. Andy555
    Slovenia
    Finaly i get it on,tnx to hair dryer and you guys.
    Stumplifter likes this.
  9. Andy555
    Slovenia
    Slowly is moving.but important is that is moving,hheehe
  10. Andy555
    Slovenia
    Slowley is moving my project.a lot of things is needed before will go on road.
    JohannesSwe, Stumplifter and k-moe like this.
  11. Andy555
    Slovenia
    Fixed holes in front light( homemade)
    Fixed shifting problem
    Fixed clutch wich sliding with high rpm,need yust loose it.
    Mount front blinkers and you see on pics.
  12. hogfiddles
    I would highly recommend re-doing your brake pedal so that the rod from the pedal to the pivot is PULLING rather than pushing. The way it current is is not the best.....if you stomp on the brake hard in an emergency, that rod could fold up. Then you'd be in a world of hurt. Re-position so the forward control PULLS the rod, AND the brake link from the pivot PULLS on the brake arm on the cover. It's easy......move the rod and the link to a position ABOVE the shafts rather than below.
    dkavanagh and chacal like this.
  13. Andy555
    Slovenia
    Tnx ,i will check how to fix that,tnx
  14. Andy555
    Slovenia
    Fixed front brake(filled with dot,5 min and was finished.very happy with that method.
  15. Andy555
    Slovenia
    Any idea how to swap up brake rod becouse all i can see is no space or i just dont have the wright pics in my head.
  16. Andy555
    Slovenia
    Member
    Put speedometer on 0 and change srews on it becouse was all rusted and damaged.
    Ok lets live 100 meters ok,hhehhe.
    New bolts.
  17. Andy555
    Slovenia
    Sealed good ,water dont came in.
  18. Andy555
    Slovenia
    And the location of speedometer on bike
  19. hogfiddles
    Nice dent on the front left of the tank!
    "Au contraire", you say?
    First time you put your bike on the side stand and walk away, the front is going to flop left and ram the speedo right into the tank-----right into the afore-mentioned dent that you now have.
    First sharp left turn, first sharp left evasive maneuver, first time backing upinto a parking spot on the left, etc......you'll find out about the upcoming dent
  20. hogfiddles
    Longer bushing to get the lever out from behind the side cover
  21. Andy555
    Slovenia
    I have 4cm space betwen speedo and tank when i turn left.
    Hmm if i make longer bushing(spacer)is the same like now.becouse if i hard pres in emergenci is posability that this spacer break and have the same problem,this is just my thinking.realy i dont know what to do.
  22. hogfiddles
    If you have that much space, cool. I can't see it.
    Use hardened hardware. If you're on the brake hard enough to bend stuff, your rear brakes would, I'm sure, already be locked up..... In which case, you're already in about to be in a different world of hurt
  23. Andy555
    Slovenia
    Tnx mate for helping .i'll starz on full my brains hhehehe to find good solution hheehhe
  24. Andy555
    Slovenia
    One more thing do you know if switc of clutch on handelbar is the same like of brake on handlbar,if yes how i get out the switch of clutch becouse on my brake is missing
  25. hogfiddles
    There is a small hole underneath....push a small screwdriver in gently to depress the plastic barb in there. That will allow the switch. To slide out
  26. Andy555
    Slovenia
    Tnx i get it out but is not the same like for brake,becouse work diferent.
  27. Andy555
    Slovenia
    Cleaning carbs.
  28. Andy555
    Slovenia
    I hope that i get it wright,becouse here in slovenia we dont have a good clinic for it.
  29. hogfiddles
    You've taken it this far apart.....take it the rest of the way apart and do the throttle shaft seals and the fuel rail o-rings, too. If you don't, you'll soon wish you did......especially when you have to tear it all back down to do them.
  30. Andy555
    Slovenia
    Aha om just affraid that i will cant bent inaf the springs or is nor soo much difficult
  31. JohannesSwe
    JohannesSwe New Member
    Gothenburg, Sweden
    Its not that hard andy. I did it myself just recently without any prior knowledge. BUT! Take a million pictures from all angles on everything. That really helped me getting the springs back correctly. And get the seals and orings from chacal.
    Stumplifter and TheCrazyGnat like this.
  32. Andy555
    Slovenia
    Ok tnx mate i recenrly take pics of everyrhing .i will take of that to ,i will try.hhehehehe lets see
  33. Andy555
    Slovenia
    Ok carbs are a part and now 24 hours must stay in soap for aluminium.lets see what will happen
  34. Andy555
    Slovenia
    Carbs are together and ready to go on bike ,that cleaner didnt make wright magic need some better.
    REUBEN likes this.
  35. Timbox
    Nice!
  36. hogfiddles
    And we are always here to help you put things Back correctly
    Dadoseven, Lightcs1776 and Andy555 like this.
  37. Andy555
    Slovenia
    Tnx
  38. Andy555
    Slovenia
    One question ,can anybidy tell me where is the diference of my bike wich have just 37kw and other with 52 or 51 kw?
  39. Stumplifter
    near Irma, WI
    14-15kw.
    hogfiddles likes this.
  40. hogfiddles
    Good one --- lol
    Reminds me of a time years ago when a co-worker was staring at a shelf of cleaning fluids and asked, "what's the difference between the yellow fluid and the green fluid?" I quickly replied....(you guessed it)......,"the blue fluid."
    Coffee dripped everywhere.
  41. Andy555
    Slovenia
    Hahahahha,funny a hahha.i understand that soo much diference is imposible,but in my papers for registration is writted that bike have just 37.
  42. Andy555
    Slovenia
    That have bike of my kid
  43. Andy555
    Slovenia
    Ok abouth bike is like this: first valve cover gasket -after aroumd 40km he push bouth half moons out and brake that moons-temporary i fix it soo i can ride but i need to change it or make some alu moons and reasembel cover without gasket,next-carbs #2 start spliting gas in airbox soo it needed to open when i open it i found that i didnt clean soo well one port it didnt work soo well ,soo i clean all four again reasembel everything then put mix screws on 2.5 turns and start the engine .then was the fun part to sync with ear hhehe,but we maid it and bike run super ,ok maybe he need some super littel touch of sync.but if you listen it is sounds very well with ear sycn.works on around 1000rpm (if is stand or i i put it on side never bance rpm) i think we make it well.
    I will try some day,ok when i buy ,a color tune but first i need to solve that cover gasket .
    On bike i clean and change the oil in front forks and put another spacer of 4mm in,the i cut rear springs for 2cm,then we test rear shock and they work like a new even they are old more then 30 years.
    I future: came new rear mirrora on the side of bar,like to try pods to see how works,other turning lights with bulbs now are led-i dont like it,next year all bike in new paint-when i will finish all cuttings ,reasembling,fixing, and ....
  44. Andy555
    Slovenia
  45. Andy555
    Slovenia
    This morning have a nice ride with bike all the family around the neighboring villages.bike works great DSC_0032.JPG
  46. Andy555
    Slovenia
    In working my homemade
    Do you know what is this for ?hehhhehe
    I yust hope that will not be to low,for my sweet wife.
  47. Andy555
    Slovenia
    Haahahaaha again in parts
  48. Andy555
    Slovenia
    New location of contact key
  49. Andy555
    Slovenia
    Slowley is move. Any sugestions welcome,but must to tell you that i will not put it in stock.this bike will never be in original,becouse i like to build it for my kid,yeap my kid is 4year old ,this dont mater,bike will be here thill will groun,thill then i or my wife will drive it,hhehhe.in small i need bikes for my all family.hhehe like to experience it that we all go ride.
  50. Andy555
    Slovenia
    Some new update...
