New parts question, XJ400 Special
Discussion in 'XJ Technical Chat' started by el_flaco, Nov 14, 2020.
  1. el_flaco
    el_flaco New Member
    Hi all.
    So I'm rebuilding the engine of my 1981 XJ400, 54 000 km. Just wanted to know if I need new primary and cam chains and also new piston pin circlips. The service manual actually indicates to use new circlips, but I thought I could get away without doing that. As for the chains, I'm not sure how I can check if the they are still good, nor can I find where to buy new ones in case I need them.
    Any advice will be appreciated!
  2. Franz
    I would use new circlips. Check your cam chain tensioner if it is fully extended then replace the cam chain. Not sure about the primary chain setup on the 400 someone will.
    el_flaco likes this.
  3. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    el_flaco I would love know if the XJ400 has the same bottom end as the 650+
    I'm wondering about the chains in your case aswell as they, from what I've read, may behave like drive chains in the XJ550.
    Let's see what we can what we can find out.
  4. cds1984
    Damn... nothing in the XJCD that helps. I suggest you put a PM into Chacal who knows all there is to know about XJs.
    Good luck!
  5. k-moe
    Reusing piston pin circlips is a recipe for disaster. They have already been through a ton of heat cycles, and the bending that occurs when removing them is the final step toward failure.
    chacal and el_flaco like this.
  6. k-moe
    It does not.
    The 400 is the precursor to the 550.
    Of course that depends on which 400 is being referenced. The twin or the inline 4.
    The twin is an entirely different animal. More akin to an XS650
  7. el_flaco
    el_flaco New Member
    Thanks for the reply! You recon circlips from a hardware store will do or I should use only Yamaha ones?
  8. el_flaco
    el_flaco New Member
    Thanks for trying to help out! I guess I'll PM Chacal then.
  9. el_flaco
    el_flaco New Member
    I also noticed that many parts are the same as in 550... and by the way I was referring to the inline 4, didn't even know there was a twin!
  10. Franz
    Only Yamaha ones. You don't want a circlip failing in your engine. They are inexpensive in comparison to the damage a gudgeon pin will do to your cylinder.
  11. el_flaco
    el_flaco New Member
    Got it, just wanted to be sure.
    Franz likes this.
  12. hogfiddles
    Xj400 - in-line 4 cyl
    Xs400 - twin
  13. John Mc
    John Mc New Member
    Liverpool
    Hi Guys,
    Sorry to butt in on the thread but......
    I've come across a Xj400 - in-line 4 cyl 1981 which has been dry stored for 30 years, looks to be in good shape, complete but will obv need dismantling and servicing....
    Am wondering of the scarcity and value of something like this?
    It is in very good shape...
    Thanks in advance..
    J
  14. Dave in Ireland
    Ireland
    Please enter a valid message.
    Well, phooey.
  15. hogfiddles
