New rider
Discussion in 'XJ Technical Chat' started by Alex Rodriguez, Apr 18, 2017.
  1. waldreps
    waldreps Active Member
    Henning, MN
    Mine did the same thing. I tried extractors but they broke off in the bolts. I ended up buying a good used bracket to replace mine.
  2. Alex Rodriguez
    Alex Rodriguez Member
    Spencer ny
    I actually got them drilled out took some time and patience and snap on owes me a new set of drills but it's done
  3. Alex Rodriguez
    Spencer ny
    Another question when I go to start my bike it will only start full choke and after its start it quickly starts to raise rpm stays at 4 or 5k. After driving for a little of I pull the clutch in it also starts to raise rpm any ideas?
  4. Jetfixer
    Your carbs are not in synch or you have a vacuum leak , this is why you have a hanging idle , have you tried backing idle knob off ? What condition are your boots in ?
  5. Alex Rodriguez
    Spencer ny
    I have t tried backing the idle knob off yet and the boots have some cracks in them. I was also wondering I drive it for like five minutes the other day and luckily at the end of my ride the bike won't stay running with the choke open and with the choke closed it's starts reving up high same thing or no?
  6. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Still this ^^^^
