New seat foam...
Discussion in 'XJ Technical Chat' started by jmilliken, Mar 13, 2016.
  1. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    The foam in my seat is shot, I was thinking about using a memory foam pillow or mattress cover somewhere in there. Has anyone done this? How were the results?
    you just have to shape it to fit
  3. Alan63
    Alan63 Active Member
    Saskatoon,sask. Canada
    I don't think memory foam is the best IMHO . I think it is too soft . An upholstery shop or even a larger sewing supply shop likely has what you should use, although memory foam might be ok atop a higher density foam , as in if you were adding it to what exists now.
    Alan
    This is a great site about modifying motorcycle seats. http://www.diymotorcycleseat.com
    Memory foam os a no-go. It just does not provide enough support in a dynamic environment.
  5. Polock
    carpet pad from the carpet store dumpster
    jmilliken likes this.
  6. hogfiddles
    Oooh.... A new model---
    xj700 Dumpster
    boomerangg22 likes this.
  7. jmilliken
    Dillsburg, PA
    @Polock - brilliant as always
  8. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    Keep away from the yellow stained under pad!
  9. jmilliken
    Dillsburg, PA
    Thanks for the tip dude.
